Alarm keeps activating after locking
bigtasty
Had the new S5 for a month now. My alarm keeps activating itself ~5 seconds after locking via the key fob. Doesn't seem to matter what key I use and whether interior monitor is on/off.
Any ideas before I take it back to Audi? I tend to get home post 10pm each night, neighbours are getting ******!
Picture because why not
IMG 2854
IIRC this happened to me when I had left something on the rear seat. It’s all to do with the rear seat occupancy settings.
Ok thanks, will try disabling the rear seat sensor, see if it improves. There's definitely nothing on the rear seats so maybe a faulty sensor. A friend has a HEX-V2 he can plug in so will check for fault codes also. Thanks for the tip!
Chaps and chapettes, will Audi get ****** if I clear fault codes using VCDS? It's thrown up a whole bunch of errors, nothing has been cleared since it left the factory by the looks.
Code:
Chassis Type: FU-AU40 (85F)
Scan: 01 02 03 09 13 15 16 17 19 22 29 2C 32 36 39 42 44 46 51 52
          5F 61 69 6C 75 7E 81 82 8B A5 BB BC C4 C5 CA CC DE 8103 8109 810A
          810B 810C 8117 8119 811E 811F 8120 8121 8122 8124 8125 8128 812C 812D 8132 8133 8136 813F 8147 8153
          8157 C002 C003
VIN: *   Mileage: 1696km-1053miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
29-Left Light -- Status: Malfunction 0010
2C-Rear pres. detection -- Status: Cannot be reached 0100
32-Differential Locks -- Status: Malfunction 0110
36-Seat Mem. Drvr -- Status: OK 0000
39-Right Light -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
51-Electric Drive -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
75-Telematics -- Status: OK 0000
7E-Ctrl Head Dash -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: Malfunction 0010
8103-Driver assist main -- Status: Malfunction 0010
8109-Close Rge Radar 1 -- Status: Malfunction 0010
810A-Close Rge Radar 2 -- Status: Malfunction 0010
810B-Close Rge Radar 3 -- Status: Malfunction 0010
810C-Close Rge Radar 4 -- Status: Malfunction 0010
8117-Rear surroundings cam -- Status: Malfunction 0010
8119-Multifunc. St. Wheel 3 -- Status: OK 0000
811E-Burglary Protection FL -- Status: OK 0000
811F-Burglary Protection FR -- Status: OK 0000
8120-Burglary Protection RL -- Status: OK 0000
8121-Burglary Protection RR -- Status: OK 0000
8122-Burglary Protection Interior -- Status: OK 0000
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: Malfunction 0010
812C-Drive/Chassis Main Ctrl -- Status: Malfunction 0010
812D-Snd enhanct 3 -- Status: Malfunction 0010
8132-Electrical system main 1 -- Status: Malfunction 0010
8133-Low voltage power distrib. 1 -- Status: OK 0000
8136-Close rnge comm antenna;drv side -- Status: Malfunction 0010
813F-Main; cockpit system 1 sound -- Status: OK 0000
8147-Passenger displ for multimedia -- Status: OK 0000
8153-Main; cockpit sys. 3 Android -- Status: OK 0000
8157-Burglar prot. 6; veh. interior 2 -- Status: OK 0000
Code:
          8157 C002 C003
VCDS can't read newer cars properly because of SFD. It's likely that those "faults" are not faults and VCDS can't talk to the module until SFD is unlocked.
Oh interesting, good to know thanks. Guess I'll just give the car to Audi and see what they come up with.
Reactions: alps26
Funnily enough my alarm went off (had the car two weeks) when sat on the drive.
Now I have the rear middle seat belt binging going off even though nobody is sat there. So I have plugged the seat belt in to shut it up.
Alarm not gone off since
Off to the stealer I go !
What's going on with the rear seats!? Been doing some testing, seems that deactivating rear occupancy detection each time I turn off the ignition has fixed my alarm issue. Will still take it back to Audi, see if they can sort it.
