Q5 Air suspension retrofit or Koni Special Active on Q5 B9
mistaleung
I love my car, it is comfortable and practical
As a family car, I am trying to push its comfort level to the maximum level
So far, I have done acoustic glass retrofit, Fine Ash Grain interior trim, OEM Deep-pile textile floor mats and sound deadening
I am now considering an air suspension retrofit, found a second hand set and the total cost with installation is approx. $4,400 USD
It will cost me a fortune, and will likely to increase the maintenance cost
On the other hand, I have heard good things about the Koni Special Active shocks, which focus on comfort and high speed stability
It only cost a fraction of air suspension retrofit
Is it worth to pay more than $4000 USD for an 2nd hand air suspension?
How is the comfort level of an air suspension? (I have never ride or driven a car with air suspension)
Does it make more sense to install the Koni instead?
Thank you
i'd check on the koni website first because if yours has s-line suspension it might not be for your car something todo with the oem s-line springs being shorter than the normal ones and if fitted regardless of this warning you'll void the warranty... so make sure, if your car is an s-line spec it might not be an option.
How old is the second hand system? Air springs can fail around 100K miles and aren't cheap to replace.
