- Joined
- Jan 26, 2017
- Messages
- 15
- Reaction score
- 2
- Points
- 3
Hi all,
Apologies if the answer is somewhere in a thread, I've had a look but cannot find the exact answer.
I'm planning on changing the front discs and pads on my 2018 RS3 Sportback this weekend.
I can see when removing the two 21mm caliper mounting bolts, you should replace them with new bolts. I wanted to ask if anyone knew the part numbers for these bolts or does anyone know the measurements so I can order some.
Whilst on the topic, I've got the following, am I missing anything?
- Discs and Pads
- Nail punch
- Hammer
- Socket and Spanner set
- Caliper hanger
- Torque wrench (1/2 & 1/4)
- Impact wrench
- liqui moly anti-squeal spray
- Brake cleaner
- Wire brush
- Anti seize to put on hub. (some have said do this, some have said don't)?
Also again apologies if this is a dumb question, the T-30 Torx for the disc. Is there a certain torque spec for this?
If I get enough time, I'll be doing the rears too but need to order the software solution (going to be using Carista) to retract the EPB.
Any tips or anything I've missed would be much appreciated.
- Discs and Pads
- Nail punch
- Hammer
- Caliper hanger
- Impact wrench
- Brake cleaner
- Wire brush
