PFM upgrade issue?
Crewe
Need Help!
Bought a full power fold mirror kit & after fitting & coding, there's no power to mirrors, C/L or mirror indicators.
Windows & alarm light are only things that work.
Part No for the modules is 8x0959792 & 3c.
Std modules end in F.
Anybody with PFMs able to tell me if these are the right modules?
Check wiring hasn't changed as on some years even the same chassis, different door modules had wiring changes.
Revert modules & if all works again, it is wiring or modules, I'd go with former tbh.
Have reverted back to old modules & everything works, purely so i can lock the thing.
Guy who coded it said there was an open circuit flagged up, but had no idea what it was.
Even switch lighting didn't work so there was no obvious power? I assume the main power came through 2 larger terminals in the blocks.
Only things that worked were windows, pass airbag switch, alarm led & speakers.
Update, had some reversing sensors fitted by Autolec & they work fine.
While he was there, they checked the coding on PFMs & made sure everything was correct & on.
However, he said there was no power to the modules & said it probably wasn't set up for PFMs in the BCM.
Now looking at the Internet (never lies) Coding is what changes the BCM & that when coded they should work.
Any new suggestions? Currently have the PFMs on but original modules so i can still operate everything else.
It's not only coding, wiring changes over the years even on the same chassis type, eg 8P had door wiring changes aswell as door module changes, you need someone on it that knows what they're doing tbh.
