Evenings,
I have a 2012 2ltr TFSI Quattro Sline.
I have had many b5 / b6's but this is my first b8 after a break from Audi's
Body work, interior, engine and transmission are really good but unfortunately it transpires it spent a lot of it life on the north coast of Scotland and is pretty crusty and corroded suspension / running gear wise.
Recently we did the front wheel bearing and rear dampers and broke nearly every single bolt we touched.
The front drivers side is sitting 10 mm to low and the bottom of the spring has corroded out, there is zero chance the pinch bolt is coming out!
I am thinking due to corrosion it will be quickest and easiest to just buy a full drivers side hub and suspension assembly and replace the whole lot while just retaining current brake caliper.
My question, would the front assembly off a diesel Quattro be the same as a Petrol quattro as the diesel are far more common?
Any advise would be appreciated
Raif
Raif
