- Joined
- Jan 19, 2025
- Messages
- 12
- Reaction score
- 0
- Points
- 1
- Location
- Romania,Timisoara
- Website
- www.tiktok.com
Hi guys, The car has been losing power for some time now, the tachometer fluctuates occasionally (at a constant speed of 50 km/h, it oscillates by 100–200 rpm, stabilizes, and then after 10 seconds it happens again, and so on) and the car stops while driving (right before stopping, the red oil warning light appears, and the engine dies. After that, it won’t start until I disconnect the battery terminal).
I should mention that someone tampered with all the vacuum hoses! Since then, it has no power. I’ve looked for diagrams but cannot find the exact ones for this model. I also have two hoses under the exhaust manifold, and I swapped them around so much that I’m at my wit’s end.
I’ve replaced: the fuel filter, cleaned the EGR and intake manifold, replaced the glow plugs, cleaned the ECU connectors, and the oil pressure sensor.
I’m attaching the VCDS scan:
Audi A3 8L 1.9 TDI ALH 1998 230000km
Chassis Type: 8L - Audi A3/S3 (1997 > 2005)
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Mileage: 231110km-143605miles
Address 01: Engine Labels: 038-906-018-AGR.lbl
Part No: 038 906 018 BB
Component: 1,9l R4 EDC 00AG 1818
Coding: 00001
Shop #: WSC 63142
VCID: 57EB8B41861E9A621E1-4B1E
2 Faults Found:
00575 - Intake Manifold Pressure
17-00 - Control Difference
00550 - Start of Injection Regulation
Readiness: N/A
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 ES
Component: AG4 Getriebe 01M 3712
Coding: 00000
Shop #: WSC 00000
VCID: 055791092C32D8F23CD-0962
6 Faults Found:
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
00660 - Kickdown Switch or Throttle Position Sensor
27-10 - Implausible Signal - Intermittent
00529 - Engine Speed Signal Missing
35-10 - - - Intermittent
00545 - Engine-Transmission Electrical Connection
31-10 - Open or Short to Ground - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01312 - Powertrain Data Bus
Coding: 00001
Shop #: WSC 63142
2 Faults Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
6 Faults Found:
