Had this myself and no answers were forthcoming. However, my battery died and when I changed it over, mirror went back to auto dipping. Maybe you could disconnect it and then reconnect to see if it helps.Has suddenly stopped working when I put the car in reverse. Mirror adjustment still works.
Any suggestions where to look first/what the problem is most likely to be?
Would have been easier to just disconnect the hinge connector momentarily & reconnect, saves removing doorcard bud.I had this also .
Went into vcds turned off then back on , no change .
In the end I removed door card and disconnected the door module .reconnected and working fine , so similar to disconnecting the battery as above
Sent from my SM-S901B using Tapatalk
