After every drive over 5 minutes, after switching the engine off, the cooling fan kicks in and stays running for approx. 5 minutes. My daily commute to work is 30 mins (20 miles) each way, and when I arrive to work or home and switch the engine off, the cooling fan kicks in. Sometimes after a 10 minute drive, the cooling fan will kick in after shutting the engine off. Some other symptoms I’m experiencing; idle revs are always 950rpm, the start/stop never works, my coolant temperature never exceeds 75 degrees (live data on OBD11). I’m planning to change the thermostat next week as I’m certain the coolant temperature should be up around 90 degrees.
After a long drive, about 40 minutes or so, if I stop the car for 10 minutes, then go to drive again, the idle revs seem to return to 820rpm and the cooling fan doesn’t run after I’ve stopped the car. Any ideas what’s going on please?
My engine is 2.0ltr, CGLC, with automatic gearbox.
