Car is a 2020 RS3 8V.
I had a rattle in the passenger door, removed the door card had a good check and all seemed fine.
I figured I check the drivers door while I was on with it, door card off, all OK and replaced as removed.
Then later I realised I had no power to the drivers door window and mirror control.
Nothing works from the door controller, windows nor mirror adjustment.
The only window that works on its own switch is the near side rear door window, the other three do not work.
I`ve had the door cards back off, checked everything is connected OK, all connectors look OK.
Checked fuses too and all seem OK.
I have OBDEleven, the scan showed - Driver door - Trouble codes: B178301 - function lighting central locking electrical error.
The car does lock.
I can`t find anything on the net relating to trouble code B178301.
Am I missing something? Does it need some kind of reset?
Any help appreciated.
The car does lock.
