Recommendation for auto electrician
trademark2k6
Birmingham
Hi everyone
My A6 (2011 C7) has all of a sudden stopped starting! Won’t even go into ignition when you press the start button.
Central locking and MMI, radio, lights etc all still work. I tested the battery and that reads 12.9v. I also tried attaching jump leads to another car and that didn’t help.
Had it scanned by someone with VCDS and the only code shown on car was to do with electrical fault in circuit (copied below).
As the wheels are locked, getting it towed garage to garage is hard and expensive!
Does anyone know of anyone who will be able to sort this issue. Presumably an auto electrician or VAG specialist?
I’m in Birningham.
Any help appreciated as the car is also half blocking my driveway!
Many Thanks
Z
Address 05: Acc/Start Auth. (J393)
Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BN
HW: 4H0 907 064 BN
Component: BCM2 2.0
H31 0330
Revision: 00002001
Coding: 03B83006000000000000
Shop #: WSC 02311 785 00200
VCID: 76E353DFC1C7343BE9-8022
1 Fault Found:
02071 - Local Databus
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 236938 km
Time Indication: 0
Date: 2024.12.08
Time: 03:10:49
Given the symptoms you describe, the problem appears to be a starter circuit or electrical fault, possibly related to a relay, fuse, or communication issue with the immobilizer.
Hi everyone
I’m in Birningham.
Many Thanks
Z
HW: 4H0 907 064 BN
Component: BCM2 2.0
H31 0330
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 120
Mileage: 236938 km
fr legends hile
Time Indication: 0
Date: 2024.12.08
Time: 03:10:49
Hi Z, sounds like an ignition switch or starter motor issue. Try a VAG specialist like Midland VW or Unit 20 in Birmingham. Check fuses/relays too. Hope you get it sorted!
Try contacting a mobile VAG auto electrician when I had a similar BCM2/databus issue on my A6, a local specialist came out with VCDS and sorted it without needing a tow.
basketball stars
