SQ5 Sq5 B8 Macan sway bar
bigal23
Hi,
Has anyone fitted the front and rear sway bars from a Macan? I believe they fit and have part numbers similar to those of the sq5.
If anyone can shed some light on this it would be great, thank you.
Ok, so no one knows.
So I have ordered them and will report back if they fit and work well.
Taken from another Audi forum
Information sway bars Audi Q5, SQ5 Front 8R0411309C - 29.7mm, rear 8R0311305Q - 22.5mm.
Macan sway bars information and what is needed for installation:
Front sway bar
— 95B411309A
— 95B411309C
— 95B411309E - the maximum rigidity - 31.5 mm
- Sway Bar Bushings 4D0411327J x2
Rear sway bar
— 95B511305
— 95B511305A - 25.7 mm
— 95B511305H – 24.5 mm
— 95B511305J – 25mm – not sure (25.45 measured by BigAl23)
— 95B511305E - the maximum rigidity - 26.2 mm
- Sway Bar Bushings 95B511035 x 2
- Clamps 95B511439 x2
- Bolts N10695701 x4
- Sway Bar End Link 95B505465 x 2
Best is E+E for maximum stiffness.
I have Front E + Rear J as I could not get an E second-hand. After speaking to Porsche the rear is only £200 for the E. The front is the most expensive but it only cost me £60 second-hand
The rear cost me £145, the front £60, P&P was £40 for both. Fittings some from Porsche some from onlinecarparts cost around £70
