Hi all,
A couple of days ago my heated seats and interior lights have stopped working. I’ve checked all the fuses and they are all fine.
Could it be a BCM module issue?
Scanned with VCDS and the only fault(s) I’m getting are the following:
Address 09: Cent. Elect. Labels: 5Q0-937-08X-V2.clb
Control Module Part Number: 5Q0 937 084 CF HW: 5Q0 937 084 CF
Component and/or Version: BCM MQBAB M+ H34 0236
Software Coding: 000000000000000000000000000000000000000000000000000000000000
Work Shop Code: WSC 06385 790 00016
ASAM Dataset: EV_BCMMQB 017001 (AU37)
ROD: EV_BCMBOSCH_017.rod
VCID: 7EF3F07FE12A9666B9-802A
1 Fault Found:
15360512 - Component Protection
U1101 00 [00001001] - Active
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 163877 km
Date: 2024.11.14
Time: 14:09:30
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.6 V
Outside temperature: 13.0 °C
Address 19: CAN Gateway Labels: 3Q0-907-530-V1.clb
Control Module Part Number: 3Q0 907 530 C HW: 3Q0 907 530 C
Component and/or Version: GW MQB High 515 5286
Software Coding: 030100041F0873005B0002481C0B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013020 (AU37)
ROD: EV_GatewNF_VW37.rod
VCID: 2F6D1D3B76C0AFEE62-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 163877 km
Date: 2024.11.14
Time: 14:09:31
Terminal 30 power supply: 14.6 V
Terminal 15: On
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 163877 km
Date: 2024.11.14
Time: 14:09:30
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.6 V
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 254
Mileage: 163877 km
Date: 2024.11.14
Time: 14:09:31
Terminal 15: On
