The Ultimate B7 Rear End Refresh Parts Guide
Bradderz_1988
Dont replace it, Upgrade it !!
North West
As some of you may be aware ive recently done a rear end refresh to my B7 DTM going with aftermarket Verkline bushings etc etc
Now some people may want to renew some life in there B7 but not compromise the OEM drivability and feel as most our cars will be our daily’s.
So ive done some digging into OEM equivalent equipment mainly Meyle components were possible to make a ‘Ultimate’ part listing for the B7 now some of these parts will apply to standard/sports suspension cars and also Quattro/FWD cars but it should cover all B7 but please take it with a pinch of salt, some of these parts did say they wasn’t applicable to my car but i have used part numbers from another source and also Autodoc which is a relatively cheap parts supplier and ive never had issues.
Here is the list if anyone feels i have missed any components i will do my best to add them to the thread.
Lower arm inner rear
Meyle 1005050005 (X2)
Lower arm outer
Meyle 1005050006 (X2)
Lower arm inner front (2 per side)
Meyle 1005050007 (X4)
Hub carrier bush
Meyle 1005050008 (X2)
Subframe bushes rear (rear)
Meyle 1005050009/HD (X2)
Subframe bushes rear (front)
Meyle 1005050010/HD (X2)
Stabiliser arm lower
Meyle 1160350001 (X2)
Upper control arm right
SKF VKDS421027
SKF VKDS421028
Rear Anti-Roll Bar Bush
Meyle 1006150000 (x2) (Suitable for 20/22mm)
Rear Drop Links
Meyle 1160600027
Lemforder 3101201
ABS Sensor Left
Meyle 1148000034 (Xenon levelling)
Meyle 1148000023 (halogen cars)
ABS Sensor Right
Meyle 1148000023
Rear Top mounts
Meyle 1007410000
Bump stops/Dust protectors
Meyle 1007400007 (Standard suspension)
Meyle 1007400008 (Sport suspension)
Wheel bearings
FAG 713610710 (Steel Hubs)
FAG 713610430 (Aluminium Hubs S4/RS4)
Wheel hubs
Meyle 1004070068 (X2, pressed in bearings)
Meyle 1006500014 (X2, bolt in bearings)
Rear CV boots inner & outer
Löbro 305123 (X2)
Löbro 305124 (X2)
Rear Diff front mount
Lemforder 2931901
Rear diff subframe bushings
Lemforder 2932101 (X2)
Rear Spring seat upper
Genuine 8E0512149P (X2)
Rear Spring seat lower
Genuine 8E0512297J (X2)
Rear springs
Eibach R10158 (Standard suspension)
Eibach R10274 (Sports suspension)
Eibach F11-15-003-03-HA (Pro kit)
Rear Shockers
Bilstein 19-158952 (Standard suspension)
Bilstein 19-164489 (Sports suspension)
Bilstein 24-119795 (B6 Performance)
Bilstein 24-119825 (B8 Performance)
A4 Quattro 18mm rear ARB kit
18mm Sway Bar 8E0511409AQ
18mm Bushings 8E0511327A (X2)
Bushing Brackets 8E0511439 (X2)
Bolts for Brackets N10127707 (X4)
Bolts for ARB links N10528103 (X2)
S4 20mm rear ARB kit
S4 Rear Sway Bar 8E0511409AQ
S4 Rear Sway Bar Bushings 8E0511327D (X2)
RS4 22mm Rear ARB kit
RS4 Rear 22MM Sway Bar 8E0511409AL
RS4 Rear Sway Bar Bushings 8E0511327D (X2)
Corrected errors and added the Meyle bushings and correct brackets for these
Meyle 18mm Bushing 1006150000 (X2)
Bushing Brackets 8A0511439 (X2)
S4 Rear Sway Bar 8E0511409AJ
S4 Rear Sway Bar Bushings 8E0511327A (X2)
Meyle 20mm Bushing 1006150000 (X2)
RS4 Rear Sway Bar 8E0511409AL
Meyle 22mm bushings 1006150000 (X2)
Reactions: northpole
Great work chap, will be a really good point of reference to many of us going forward.
now a sticky thread too. :thumbs up:
Reactions: Bradderz_1988
I highly recommend doing this with any B7 wether it be the OEM or Polybush route and id strongly recommend upgrading the rear sway bar i went with the 034 and all i can say is now its all on and fitted is WOW !!!!
Thanks for making it a sticky also
The rear arb upgrade is a very worthwhile investment, it really makes a big difference, what type of arb one chooses is a personal preference but the upgrade is very worthwhile investment.
I was fortunate to have the larger RS4 arb factory fitted from new so I can’t say from experience how much the improvements is over the standard arb, but, my old bus handles really spot on and always has done so I can say , if you haven’t upgraded, do it , you won’t look back.
