Facelift B&O Issue After Upgrading to MIB2 High and Gen2 Amp
ogulcancetin
Ankara
Hi all. I have a 2020 A3 sedan(8V facelift). Approximately 5 months ago I've retrofitted the complete B&O system with a MIB2 STD head unit and gen1 amp. It was working perfectly. I had sound controls bass treble subwoofer, surround effects etc. A week ago I've decided to upgrade my car with the Harman MIB2 High unit and gen2 amp. We've got CP removed and coded both units. Unfotunately, rear door speakers and the right surround spekar near to the subwoofer are crackling on low frequencies and high volumes. Also after some time driving around and listening to music, if the volume is more than half the volume bar, volume gets noticeably lower automatically(But the sound level bar stays same). I am posting an amateur scan below. I would appreciate any suggestion and solution. Gen2 amp is not from an A3 but from an R8 i guess because the part number is 4s0 035 465
47. Acoustic system
Application data identification: --05**--
VAG Part number: 4S0035465
Software version: 0435
ECU manufacturing date (ASCII): 161019
ECU serial number: AUZ8ZAGJC0023FN
VIN: WAUZZZ8VXLA096023
Hardware Part number: 4S0035465
System supplier ECU hardware number: PA00014A
System supplier ECU hardware version: AP01
System supplier ECU software number: PA00014A
System supplier ECU software version: 1430
System designation: MIB2_amp_P_R8
Calibration date (ASCII): 000101
ASAM/ODX: EV_AMPMst16C6Gen2ALPI
Hardware version: H10
ASAM/ODX version: 001001
FAZIT Identification: 4TU-00119.10.163JC10122
Parameter set part number: 8V0909510G
Parameter set version: 0007
System abbreviation: J525
ECU manufacturing date (HEX): 161019
Date of last adaptation: 000101
Date of last coding: 240920
Diagnostic mode: 03
Parametrization date: 240923
Long Coding: 0000000000AAAA2AAA0000010000
Electronic Information System 1
Application data identification: 2*7122A2122100--0060--001110--***************************************************************
VAG Part number: 8W0035035E
Software version: 1326
ECU serial number: A390D0FB000604
Hardware Part number: 8W0035035
System designation: MU-P-LND-EU
Calibration date (ASCII): $!
ASAM/ODX: EV_MUHig6C3Gen2HBAS
Hardware version: 041
ASAM/ODX version: 001115
Parameter set part number: 8V7909545N
Parameter set version: 0016
System abbreviation: J794
VCRN: <
Date of last adaptation: 240921
Unit ID: 5F
Date of last coding: 240923
Diagnostic mode: 03
Parametrization date: 240314
Long Coding: 01730101FF00000011110002000A00002F0026E501700100FE
19. CAN Gateway19. CAN Gateway
DTCs: 1
131695 [0x02026F]
U106A00: Digital sound system control module, No Communication
Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket
Status bits: 1
Priority: 2
Frequency: 6
Unlearning index: 187
Odometer: 106377 km
Date, time: 2024.09.21 12:47:45
Status: Test failed, Confirmed
47. Acoustic system47. Acoustic system
DTCs: 7
00564 [0x000234] Archive (inactive)
B106BF0: Right effects speaker, Short circuit to each other
Verbindungen zu Lautsprechern Kanal 7, elektrischer Fehler im Stromkreis
Status: Confirmed
00570 [0x00023A] Archive (inactive)
B106513: Left rear bass speaker, Open circuit
Tieftonlautsprecher Kanal 9, Unterbrechung (DC-Diagnose)
Status: Confirmed
00575 [0x00023F] Archive (inactive)
B106713: Right rear bass speaker, Open circuit
Tieftonlautsprecher Kanal 10, Unterbrechung (DC-Diagnose)
Status: Confirmed
00580 [0x000244] Archive (inactive)
B106913: Center speaker, Open circuit
Tieftonlautsprecher Kanal 11, Unterbrechung (DC-Diagnose)
Status: Confirmed
00600 [0x000258] Archive (inactive)
B130C13: Double subwoofer speaker 1, Open circuit
Tieftonlautsprecher Kanal 15, Unterbrechung (DC-Diagnose)
Status: Confirmed
01564 [0x00061C]
B13BB13: Microphone for vehicle noise, Open circuit
Mikrofon 1 - Unterbrechung
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 106377 km
Paramteric values: 02 86 80
01600 [0x000640]
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 106377 km
Date, time: 2024.09.21 12:47:44
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 4
01555 [0x000613]
B201A00: Checking software version management
Check software version management
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 106377 km
Date, time: 2024.09.21 12:47:53
Paramteric values: 02 86 7A 10 02 4D 46 43 32 4C 33 37 78 45 2F 46 43 50 20 20 20
02565 [0x000A05]
B105413: GPS antenna, Open circuit
GPS aerial - open circuit
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 106377 km
Date, time: 2024.09.21 12:47:48
Paramteric values: 02 86 7D
06696 [0x001A28]
U10C000: Control module for instrument panel insert on optical data bus, No communication
Control module for instrument cluster display, no communication
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 106377 km
Date, time: 2024.09.21 12:48:28
Paramteric values: 02 86 84
07194 [0x001C1A]
U111100: Function limitation due to missing message
Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 106377 km
Date, time: 2024.09.21 12:48:14
Paramteric values: 02 86 83 18 44 02
Would guess the parameterisation between the R8/A3 config may be incorrect?
Install / fit correct parts
You are absolutely correct. However we do not have access to all the correct parts in Turkey since the distributor of vag vehicles is a pain in the …. So we are trying to do our best with second hand parts. Now i am on the hunt for the correct amp. Hope i find it.
I have solved the problem with replacing the amp. Apparently, the first amp was faulty. Not because it was another amp but because some of it hardware was fried. I replaced the amp with a new one that was appropriate for my car, removed cp, coded and flashed the dataset. It works like a charm now.
