Mythos black paintwork
Papworth
Anyone got Mythos black paint and know of a compound/polish and pad combination that works?
I’ve tried various combinations but that clear coat is hard as nails and just doesn’t budge when trying to remove swirl marks.
Had Cobalt Blue on a Audi A2 which was basically black. Used Menzerna 203S which is a 4/10 cut. Menzerna have renamed that compound, but it came up like glass. I dampened the pad and used on a light speed range. Can't be done in direct sunlight, so if you have access to undercover space that would be the way to go. Be methodical. The temptation is to move onto other panels, but it takes time. Protection wise, then I'm old school. Collinite 476S, again applied with damp pad manually.
Reactions: HollywoodDroid
Had Cobalt Blue on an Audi A2 which was basically black. Used Menzerna 203S which is a 4/10 cut. Menzerna have renamed that compound, but it came up like glass. I dampened the pad and used on a light speed range. Can't be done in direct sunlight, so if you have access to undercover space that would be the way to go. Be methodical. The temptation is to move onto other panels, but it takes time. Protection wise, then I'm old school. Collinite 476S, again applied with damp pad manually.
What pad(s) you used?
