Air suspension, 75x clamp, V50 pump
New_Drug
Gdansk
Hello everyone.
First of all, I apologize for the spelling, but I'm writing through a translator.
I looked for a solution to the problem on various forums, but unfortunately I did not find the answer. The only thing I managed to find is some indication that the steering lock may be damaged, hence the error with the 75x clamp (but the lock works one hundred percent).
I will be grateful for any help, any guidance…
Address 05: Commissioning Permission: 4F0-910-852.clb
Element designation SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Version: 09010701 Serial number: 10601500875906 Coding: 0000135 Code
service
: WSC 11111 111 87645
VCID: 63C51 A8 BA255B197B2-8036
Subsystem 1 - Element designation: 4F0 910 131 G
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Element designation: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
2 - number of errors found. Here's one:
02401 - Clamp 75x
006 - Short circuit to positive - Occasionally
Freeze frame:
Change status: 00100110
Priority option: 2
Error rate: 2
Internal error counter: 96
Mileage: 506744 km
transmission time: 0
Data: 2007/05/17
Time: 12:40:45
In addition, I still have an error related to the air suspension and a problem with the calibration of the air suspension.
The VCDS error reads as follows:
01780 - vehicle leveling system sensor
003 - Mechanical Fault - Occasional
I looked at all the sensors from under the car and they don't seem damaged.
I also tried to calibrate the suspension height and each time the rear right wheel is about 15mm higher. I can't lower and level it. The front right one is also higher, but about 5-10mm and I can't lower it either.
Another problem is:
00739 - Coolant circulation pump (V50)
001 - Upper value extremely exceeded - Occasional
I had a problem with the air conditioning, but it was repaired and the pump in question was replaced with a new one (new part replacement, but new). There was no problem with the error for a while, but it came back and after every time I deleted it, it keeps coming back. I wouldn't want anything to happen to the air conditioning again because of this pump.
Is anyone able to help me? I will be very grateful.
