Hi everyone, last year i've bought a beautiful 8V with only 40k km on the clock, it has everything I wanted and then some. The previous owner has done some mods to the car which is why i think the headlight washing system does not work.
Now to the worse part, here in Portugal if the car has headlight washing system it needs to work in inspection but I've never seen it work. I have access to VCDS and I've done an auto scan it's down here.
I've also went into 09 and checked the Channels that i could find related to them like Scheinwerferreinigung Headlamp washer system - which was off and i did enable it, the other channels that showed up when searching for Scheinwerferreinigung also had values in them, 1000 in each one, and the one that controlls number of windshield activations to activate headlight washing had 10. left it at that.
what other channels can i check before trying to get this fixed at audi (because they'll more likely remove my sports dials in my Digital Cockpit)?
is there anyway to get vcds to tell the car to use the headlight washing system or just with the stalk?
Saturday,10,August,2024,13:43:47:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ8V0Hxxxxx License Plate:
Mileage: 48990km-30440mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 6C A5 BB BC
VIN: WAUZZZ8V0HA096457 Mileage: 48990km-30440miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H23 3545
Revision: R6H23--- CVN: C7C719B6
Coding: 02190032244401083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906027HF 001006
ROD: EV_ECM14TFS01104E906027HF.rod
VCID: 6FBBD3A1171EF2A2E61-803A
VINID: 9D196AAAA2260184402461051CAF847FAA
Center armrest control head 1:
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 60057000003116
Coding: 12F16AA224291272497B0E0540CA28485624489270021472142150788028420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
VCID: 76B5E6C56844C36A257-8022
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0426685748 Dataset Number: 8V0909577E 0011
Coding: 030C0C
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_KessyHellaMQBAB 002019
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3B2337F113E65E021A9-806E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001126920
Coding: 03000004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
ROD: EV_AirCondiFrontVaAU37X_008.rod
VCID: 40D9401D7A003DDA4FB-8014
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0006
Serial number: 6A78076800PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001636300522 Dataset Number: 8V0909514T 0037
Coding: 000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5B03E1477E8222761-802A
Wiper motor control module:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 161017 043 0580
Serial number: 161031002318
Coding: 0A47F7
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62553880
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 24 10 2016 00000418
1 Fault Found:
204290 - Remote key 1
B1479 18 [008] - Current Too Low
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 186
Mileage: 46238 km
Date: 2024.04.25
Time: 20:55:31
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: Not operated
Position lamps: Not operated
Automatic high beam assist: operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.9 V
Outside temperature: 14.0 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 A HW: 5QA 919 294
Component: PDC 8 KanalH07 0038
Serial number: 000308418617007 Dataset Number: 8V0909526H 0059
Coding: 0470051001
ASAM Dataset: EV_EPHVA18AU3700000 009031
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4ACD62354C3CF78A91F-801E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Dataset Number: 8V1909863S 0001
Coding: 2D00E0C259FFC728949C8045000026
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: EV_ACCBOSCHVW416_001_VW37.rod
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2GT1H8 Dataset Number: 8V0909602M 0003
Coding: 98CCC0000C0000005C5400CA004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002154
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 1079B05D6AE08D5A9FB-8044
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: ----------- HW: 480 000 701 17
Component: SideSensor_Df 001 0887
Serial number: 35700000000EC3F8802Y
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: ----------- HW: 480 000 701 17
Component: SideSensor_Pf 001 0887
Serial number: 35800000000DC3F8802Y
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: ----------- HW: 480 401 001 17
Component: SideSensor_Dr 000 6149
Serial number: 3510001AF2404031B58U
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 401 001 17
Component: SideSensor_Pr 000 6149
Serial number: 3520001AF2404032132E
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 401 311 16
Component: FrontSensor_D 001 6149
Serial number: 3550002C322E8E11910$
Coding: 2D2D2D
Driver's side crash data pedestrian protection:
Subsystem 6 - Part No SW: ----------- HW: 480 401 201 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001BF2404033C34V
Coding: 2D2D2D
Passenger's side crash data pedestrian protection:
Subsystem 7 - Part No SW: ----------- HW: 480 401 201 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001BF2404032228O
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 8 - Part No SW: ----------- HW: 480 001 212 16
Component: PedPSensor_D2 001 0887
Serial number: I0M00000000A190DFF1I
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 9 - Part No SW: ----------- HW: 480 001 212 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000CEA5D7F1W
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 KF HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0140
Revision: -------- Serial number: 19121604401536
Coding: EC08
ASAM Dataset: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 0849983D12B0C59A47B-805C
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 HW: 8V0 920 790
Component: FBenRDW H13 0045
Coding: 048D09106F8400080081FE001000000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001023
ROD: EV_DashBoardFPKAU37X.rod
VCID: 79AFEDF9595AAC12485-802C
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005750760 Dataset Number: 8V0909515M 0084
Coding: 030100043F0857005B000258080B00000001010000000000000000000000
GVL: 01543C0000000600408C80000002480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013020
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B13A1D79EB2A2A61-807A
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 8S0 951 523 B HW: 8S0 951 523 B
Component: J453 MFL H07 0001
Serial number: 20150415104734 RD010
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75410803921611100527
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000002163002
Coding: 5500000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34311CCD3EB8917ADB3-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 061216EL52761A Dataset Number: 8V0909872J 0039
Coding: 001C9B205C00040000001003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D34F116B1626C2529-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 T HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 128 1072
Dataset Number: 8V0909852P 0026
Coding: 9107
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D75109652218F27CD-8010
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 151216ELF30586 Dataset Number: 8V0909873J 0039
Coding: 001C93205E00040000001003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DD4A15740C2FCA59F-8016
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8V1 035 036 A HW: 8V1 035 036
Component: MU-P-LN-EU 053 0875
Serial number: A699A0H2516948 Dataset Number: 8V2909545L 0020
Coding: 01730301FF0A000011110001000A00102F0026E5017001009E
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 313F15D9C1AAA452B05-8064
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Serial number: --------------------
Multimedia System 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9G1Y008MM
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL117111600010889
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1015
1 Fault Found:
1555 - Check Software Version Management
B201A 00 [009] - -
[Check software version management]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 46036 km
Date: 2024.04.19
Time: 19:40:34
Voltage terminal 30: 12.4 V
Status_Software_Version_Management-module_name: MDUA201/Front
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 4M0 980 556 A
Component: RVC Compact H19 0231
Coding: 0273010102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 392F2DF919DA6C12085-806C
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [009] - -
[RearView system not calibrated]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 186
Mileage: 46224 km
Date: 2024.04.25
Time: 20:18:36
passive
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 10011711K12220 Dataset Number: 8V0909466N 0007
Coding: 0403070300000401012223448048A90094000E100020
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_VW46.rod
1 Fault Found:
1275 - Camera Interference
C1104 00 [024] - -
[Task_Runtime_Monitoring_Zynq_0_Task_#2]
Intermittent - Confirmed - Not Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 44806 km
Date: 2024.03.01
Time: 19:54:30
Control Module temperature: 31 °C
Outside temperature: 10.0 °C
Vehicle speed: 31.50 km/h
System run time: 471.8 s
Voltage terminal 15: 14.3 V
mid: 01 62
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 071216EL710847 Dataset Number: 8V0909897H 0027
Coding: 000C93204000040000001002
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 071216EL71074B Dataset Number: 8V0909896H 0027
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.5V)-----------
www.Ross-Tech.com
Coding: 030C0C
Coding: 0A47F7
Coding: 00006C
Light switch:
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 186
Mileage: 46238 km
Date: 2024.04.25
Time: 20:55:31
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 12.9 V
Coding: 0470051001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: EC08
Generator:
Coding: 9107
Data carrier:
1 Fault Found:
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 172
Mileage: 46036 km
Date: 2024.04.19
Time: 19:40:34
1 Fault Found:
B2010 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 186
Mileage: 46224 km
Date: 2024.04.25
Time: 20:18:36
passive
1 Fault Found:
C1104 00 [024] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 59
Mileage: 44806 km
Date: 2024.03.01
Time: 19:54:30
mid: 01 62
Software_Info_4: 1
Software_Info_3: 3
Software_Info_2: 2
Software_Info_1: 0
