Is it normal for the rear speakers to be such low volume? I set the balance to rear to see what it sounds like and it’s very quiet. Is that to make it come from the front mostly? In other cars the rear speakers are just as loud as the front.
Mine are the very same, a bit disappointed in the B&O system in general, if you turn the bass up the door cards rattle too,Is it normal for the rear speakers to be such low volume? I set the balance to rear to see what it sounds like and it’s very quiet. Is that to make it come from the front mostly? In other cars the rear speakers are just as loud as the front.
The rears have woofers in the doors and I assume tweeters but just sounds very tinny. I guess this is for a reason to give sound to the front balance and not sound like it’s coming from the back?Yea the rear door mid range could with more volume, but at least they produce some music. The front door ones are woofers that only produce bass sounds. The c pillar ones are even worse. Surrounds. But in the driver's seat the music ain't bad having the 4 mid range on the dash supplemented by the door woofers
