Battery change questions?
Kuljit Singh
Nottingham
Hi guys i just replaced my battery today on my 2015 A3 8v Tfsi 150bhp Manual.
I been reading on various posts and threads that these cars take AGM batteries due to the Start/Stop technology.
Suspringly when my old battery came out, it was a Moll branded EFB battery (see attached photo)
So got it changed at Halfords with a Halfords EFB096 Start Stop Car Battery (see attached photo)
Also the start/stop was disabled prior using Carista which was not enabled.
So the battery was swapped over fine. I noticed lots of lights and warnings appeared after the car was started. The mechanic done 2 turns of the steering full lock left to right and all the lights went off. He then said its all done.
However i been reading the battery in this car requires coding/registering, so i told the mechanic to do that. He then connected a obd device and ran some process, then showed me the obd device displaying "battery installation concluded".
So should i assume the battery is now registered fine?
Also i ran a scan with Carista and quite a few faults have appeared in the results however no lights on dash (please see attached photos). Which i have not yet reset. Can someone confirm if its safe to reset these faults with Carista?
Also has any one used EFB batteries from Halfords in their A3? And whether they are any good?
Thank you in Advance.
1000068198
1000068208
1000068199
1000068200
1000068201
1000068202
1000068203
1000068204
You will get all sorts of faults coming up with an old faulty battery and with disconnecting it to replace it.
Clear all the fault codes and see if any reappear. It should all be fine now with the new battery.
Some of the errors will clear themselves after driving a few yards also.
Reactions: Kuljit Singh
You are correct a new battery in an 8V does require coding, a simple digit change to the serial number, so it sounds like this was completed. EFB are a slightly cheaper alternative to AGM batteries and are stop/start approved. I suggest you clear all your fault codes (new battery installer should have done this), drive the car and scan again a few days later but as previously said a previous dying or dead battery will cause all sorts of codes to get registered.
If you wish to have a read here's what I did when I changed my battery in my FL S3 8V and details the coding necessary. I see you're in Nottingham as am I so if you want your battery coding checked/tweaked I'm more than happy to do this, drop me a PM and we can sort it.
