2016 audi a6 white smoke
%gerry%
Strabane
Hey guys new here so forgive me.
Recently I had a dpf,ad blue and egr delete on my 2016 audi a6 sline ultra.
However the car seems like its still in limp mode and now showing white smoke.
When I try accelerate the car slowly climbs in speed but no power.
Can someone please put my mind at ease as the last month has been a nightmare so far getting things deleted and lights off the dash.
The car has 114,000 miles on the clock and very well looked after
Thank you
The DPF had been cleaned and continued to throw on the light on the dash, so I had the DPF removed and EGR deleted.
Shortly after the adblue light came on which said "vehicle will stop after 1000km", hence why that was deleted.
Seems to be a common problem with the sline ultra.
Anyway, I was now told that the reason the cars not running all horses is because the charge air cooler needs to be cleaned.
It was a great car up until revent but no more audis for me after this.
Depending on how the deletes were done you may find issues when you come to have the car MoTed. If the DPF delete is noticed it will be a fail
Just my two pennies,
I had a 2014 A6 ultra with which I did 250K miles. I had DPF issues and I also had to change out the Adblue tank once. I think you might have just got rid of the so-called problems but now are unsure of what is causing your issues. My old A6 was having DPF issues...I think it was just past it to be honest, but I had it cleaned with an on the car solution and the issue never came back, when the DPF light did come on, it went out quick too as I would drive a lot for work. It's not the Audi's that are at fault, I think you have been mis informed bu the people you went to for help.
Thanks for the reply.
Yeah the dpf got cleaned a couple of times but no joy so that was removed and it doesn't make sense having the ad blue spraying in when there's no dpf.
To be honest I'm totally turned off audi after these problems. I have it in the garage Tuesday to have the charge air cool cleaned and hopefully that sorts the lack of power but at this stage I'd be shocked if it works.
