Dyu know, I might just do this. Already one of my DRL bulbs has stopped working today, I wish I’d seen that kit before I started mucking about like I have, lolIf you have Xenon’s look at getting the EM Tuning DRL/Side kit
About the oil... depending on the mileage the engine has done... if it's over 150k miles do it a favour and go for fully synthetic 5w40... preferably the likes of big brands... why you ask? Simply for more protection on the moving parts and to minimise ware
So even these kits can give bulb out warning too? Jeez. Very temperamental with the bulb out warning on B7’s I see. Never had such issues. I’m still waiting in any case, can’t even get hold of EM Tuning, I take it they are on holiday or something.Be careful with the EM kits as they can be problematic in the b7's, bulb out errors etc.
Looks like I’ll be seeking out this tool in time for the next oil service.There is indeed a special tool to drain the oil filter housing.
it screws into the bottom of the housing and as it does it allows the oil to be drained out via a hose in a container, saves a lot of mess.
These engines have a reputation for sounding like a bag of spanners with age and milage.I’ve gone for a 5w40 fully synth this time, it’s recommended by the oil supplier we deal with at work, which is Valvoline. But I’ll change it every 6 too. I just found it really odd how I seemed to be getting a lot of noise, like tappt top end noise. And with an oil service ‘considerably’ less noise. Which does worry me that little bit about the old filter being toast a while ago, and I’m hoping no significant top end wear.
Anyway, it’s driving nice and smoothly. Just need to change the broken vac pump and they’ll be even less noise.
yes but if you have no idea when the last time was the previous owner has changed the oil... the best thing to do is to do an engine flush followed by fresh oil and filter... than monitor the noises... if they get worse soon after fresh oil there are worn parts that need to be replaced it's as simple as that.These engines have a reputation for sounding like a bag of spanners with age and milage.
numerous parts can be the cause, below are a few more common ones.
Brake vacuum pump
fuel pump and tappet
cam chain tensioner
cam chain adjuster
cam chain
oil pump and sprocket
if one is really unlucky it can be several of those combined.
changing the oil and filter won't make the problems go away but can temporarily help.
I have one at work if you need borrow it give me a shoutLooks like I’ll be seeking out this tool in time for the next oil service.
Cheers appreciate that. Are they expensive? I’m that guy who once I see a tool that needs to be used I’ll just get it and have it in the chest. Comes from years of doing jobs and not being able to complete them through not having the right tool.I have one at work if you need borrow it give me a shout
Oil i use is genuine quantum 5W40
yep, saves a lot of mess.I just use the one from our special tools room so not sure what they cost lol
Really does keep the oil filter change mess to a minimum.
Absolutely, I would as well but………..the brakes arnt staying.i'd paint the caliper carrier to match the caliper, simply because it would get on my nerves
That is a pretty normal wear and tear condition for an OE bung; they are made of polyurethane foam and just disintegrate over time.I was amazed how much the snub mount was demolished. I did put an order in for a Powerflex item, but it seems most outlets haven’t got any of these in currently. So due to timeframe I ordered a standard one. Shocking difference though. Definatly feels a bit more sturdy now when changing gears.
