Got link and pictures of your grill?It's easy enough to DIY, hardest bit is removing the old grille off the bumper because the clips are tough and you may need to adjust the foam covering the crash bar. I think there is guide on it somewhere.
I got my grille from Ali Express...I suspect most of them come from there anyway
I bought it in 2019 and the seller is gone.Got link and pictures of your grill?
Trying to find a good one otherwise splash out for a genuine rs3 grill.
This looks like a similar one: link
Message the seller and ask for some more pictures. You can also ask for the quattro emblem that goes on the bottom (if you want it). I find the sellers are quite accommodating usually, if not, move onto another seller, plenty on there.
It's easy enough. Off the top of my head (this isn't an exhaustive list as I did it years ago):Looks nice. Was that straight forward swap? Some says cutting foam, any idea what that’s about?
It’s the Maxton splitter but I took the Maxton badge offThat looks spot on. What is the splitter you have fitted if you don't mind me asking?
I've had a qoute to fit one for £140. So not that expensive to get fitted either. They qouted £260 for the grill. Or I can supply my own.It's easy enough to DIY, hardest bit is removing the old grille off the bumper because the clips are tough and you may need to adjust the foam covering the crash bar. I think there is guide on it somewhere.
want to sell you original grill?I've had a qoute to fit one for £140. So not that expensive to get fitted either. They qouted £260 for the grill. Or I can supply my own.
i'm in stoke let me know how much you would want and locationPotentially, yes
