Mvtepixels
To give some context, I had a minor crash one year ago, and had to put a new headlight on the left, costed me 750€ at the Audi dealership. Only found out about this problem because I changed the bulbs for new ones.
I have the 2015 A3 pre-facelift , and while installing new bulbs (OSRAM XENARC COOL BLUE INTENSE next Generation) i found out that the main beam point where the light is brighter is out of level.
As shown in the pictures, when it is on medium beams the lights are leveled, but the bright spot is not, when I put it on high beams it's easy to see the bright spot is out of level.
Seems to me that the problem is the cut-off shield inside the xenon projector, one shield is cutting more light than the other. At first, I thought the bulbs were the problem, but after putting the old ones back I found out the bulbs are fine.
Is that something that can be corrected on VCDS ore something, or is it a defect from the headlights?
