Changing seats
simonwright911
West Sussex
I have an Audi A6 event C7 13 plate, with heated front full functional electric seats with memory function for both passenger and driver side.
I’m buying an Audi A6 2.0 AVANT TDI ULTRA SE EXECUTIVE 5d 188 BHP 18 plate with only heated front seats.
Will my full functional A6 seats from the 13 plate fit and work in the 18 plate.
I appreciate the fixings should be the same as I cannot see Audi having different seat fittings for each Audi A6 avant modal.
Also can I put the door memory switch panel from my 13 plate onto the 18 plate door which has the same panel, but without the memory buttons.
And is the wiring for these switches already in the door or do I have to add the wiring to the door for these memory switches to work?
Well 1st is it late C7 or C8 you're getting.
If C7, More than likely needs extra wiring from my experience, you could swap over the bits before you move your old car on & have the upgrade done afterwards.
Then google the cars images, this is easy.
