AY ACC Issues
Puke
Manchester
Hi all,
Bought a 2011 272ps DTI last week and it's got ACC issues... Basically neither ACC nor standard cruise will activate at all or throw any lights on the dash, just no response. I have an OBD eleven scanner which gives two faults; Adaptive cruise sensor - no signal C110B49 and Adaptive cruise sensor - misadjusted C110300. If I clear these fault with the OBDeleven app then. all get dash warning 'ACC and fwd assist unavail' but again they disappear next engine start. I also get Crtl module faulty B200000 which won't clear at all.
I suspect the control module is dead - I'd like to start by finding the control module, checking the fuses, connections etc, maybe opening up and checking for any blown components on the board. I ca't find any information anywhere as to where etc unit is even located! I've also probably got a calibration issue with one of the sensors but no idea which one. I guess I'll need to get VCDS...
Any ideas for any of the troubleshooting for this fault would be appreciated - I have spoken to a local coder and asked if he could code out the ACC function and leave me with just standard cruise but apparently this isn't something he's willing to do.
Cheers guys
Reactions: Aesqlap
Exactly the same problem, appeared suddenly.
Have you found any solution?
