What an experience this damn Q7 has been. Awful car so far. Worst purchase decision ever. However, some fixes have been completed so that's something. Bit of advice sought on the following if anyone can kindly help:
- When I got car, vents were blowing heated air but when I tried AC it went into a locked ECON mode. Had AC regassed and that now blows cold air, although the G65 high pressure sensor still shows a lower limit exceeded error fault so could try swapping it. When I up the temps on the climate control, the blowers immediately stop sending air through and only throw out air when front demister is selected. Makes no sense as blowers obviously work! ECON still stuck on even when AC is blowing through. Tried clearing faults. Any suggestions?
- Where are the fuses for the ABS? Some forum chatter suggested by the battery under the seat but fuse diagrams say otherwise? Still have ABS/ESP warning lights so either it's bad fuses/wiring/connectors or module itself does need replacement.
- Still not solved air suspension issues. Tried new front air bags and pressure valves to no avail. Will be compressor, valve block, and relay next.
- Other annoyance is the horrible oil smell in cabin. Apparently oil leaking and pooling from around the EGR area and also the sump plug. Makes for a nasty driving experience.
Nightmare car so far! But thanks in advance.
