Iddle issue after timing belt replacement
kerim123
BA
Hello,
I have a question about my A3 2.0 TDI.
125 kw, my 2011, quattro.CFGB engine code (one from golf 6 GTD).
7,000 km ago I did a timing belt replacement at a trusted mechanic (at least I hope). He drives a 2.0 tdi cr himself, He is been in business for 20 years.
We changed everything, including a set of V belts and timing/water pump.Conti/Ina parts.
The first 1000 km after the service, the car had a strange sound, a little rougher with some strange note that I can't describe.
After 1000 km, the sound was ok, but I have another problem.
The problem is revs when idling.
I am driving the car for the third year, I know it by heart.
Before timing belt replacement car always worked when idling on either at 800 rpm or at 1000 for 20-30 sec when I first turn it on in the morning and it's colder outside (or when I turn on the heating and the car is not running on working temperature and then it goes up to 1000 and then I can hear the relay clicks).My 2 friends have cars with seme engines and their works the same as my did.
Now, sometimes, in the morning it works at 900 revolutions, like never before, for the first 30 seconds, if the car is not switched on for a long time, i.e. the whole night and it's minus outside. Then it drops to 800/1000 if I turn on the heating on,
like it should be.
The revs do not oscillate, the car does not shake, nothing strange except for those 900 revolutions sometimes.
It doesn't use any water, or burns oil, it doesn't smoke, it doesn't use more fuel than before.
Consumption in idle is 0.6 l/h when the car is running with the heating/lights on. That's ok I believe.
Battery and charging the battery is ok, checked with mechanic.
Anyone have any ideas?
Seems you can adjust the idling speed using vcds
https://www.audi-sport.net/xf/threads/186452/
I know this make not explain why the revs are higher but maybe your mechanic adjusted it?
He did not use diagnostics when replacing timing belt.
I was there whole process haha
I will check this, thanks.
Issue is, it is only sometimes…
