Help with part numbers for A4 Quattro
davsin
Isle of Skye
Hi all,
Wondering if anyone on here has access to part numbers for my car.
Put the car in on Tuesday to the local dealer for a service and to investigate a misfire at idle, they found 10 different things wrong with the car (and didn't solve the misfire after replacing the Sparkplugs), things like the gearbox oil, Air Filter, coolant level, pollen filter etc. Couple of the bigger things were the rear right spring seat for the spring has split, (don't know what it is and can't find it anywhere I have looked. Rear left Headlight level sensor seized in the open position, needs replacing, Oil Cooler leak needs replacing and finally Under trays missing, apparently come in 3 parts and covers the gearbox.
So parts are:
Oil Cooler quoted £1400
Rear right spring seat quoted £309.65
Rear Headlight level sensor quoted £367.20 (found it for £60.00 on ebay)
Undertrays Quoted £436.10
It is beyond me that a service would Cost £370 and it didn't include plugs, air filter or pollen filter, but thats the dealer for you.
Anyone who can get the part details for a AUDI A4 2.0 TFSI Quattro 252 and its a CYRB engine code Registration J666DNS it would be greatly appreciated.
Hi all,
So parts are:
Oil cooler - 06L117021G - £211.90 + VAT
Spring seat (I think this is the rubber bit that goes on either end) - Upper - 8W0512149A - £14.60 + VAT, Lower - 4M0512297B - £14.60 + VAT.
If its the rear wishbone then its - 8W0505311H - £244.50 + VAT
Rear headlight level sensor - 8W0941309E - £156 + VAT
Left underbody trim - 8W0825207C - £85 + VAT
Right underbody trim - 8W0825208C - £85 + VAT
Can't seem to find one linked to your VIN for the gearbox specifically unless I'm blind.
I would take their "repair recommendations" with a pinch of salt to be honest.
All prices above are listed at full retail for info and are the most recent numbers for your VIN.
If I were you I wouldn't be going near a main dealer, find yourself a good independent specialist.
