Media unit - main control button not working 8XA035192C, 66 plate
cartermellor
Manchester
Hello, so I have had some issues with the 8XA035192C unit - basically, the main control swivel button isn't working, so I am unable to press things such as to update/confirm tyre pressure, or press yes to pair to connect Bluetooth, all because the main one button is not working, all the other buttons are working other than this main swivel one - it has essentially broke off, but when trying to fix it, I am being quoted £3,000 as says will need the whole new unit? I just think this is a bit steep as it is one button.. Does anyone know any other way to connect Bluetooth without having to press 'pair', or any other fixes for this? Please! Thanks.
Audi1
I see this a lot. Basically the unit needs to be changed out. New is a lot but used these range from £300 plus fitting / coding. MMI part number needs to be correct for the VIn for everything yo work correctly.
