greenberry
Hello!
I'm up against some real mechanical sorcery here.
I'm having coolant leak issues in the valley of my v6 tdi 3.0 (CDUC motorcode)
I've changed to new gaskets on the base plate of the oil cooler, both sides. I've also bought a new coolant flange with new gaskets and installed it.
Now to the real issue, I keep getting leaks when refilling coolant, same place.
I'm thinking it might be 059121737AM (Cooling System Bypass Line Adapter) housing. But reading on other people having the same issue, that's usually a very small leak. (new gasket is installed on the adapter, but not changed the adapter itself yet) When I refill the coolant it seems to fill the valley to a certain point kind of fast, but seems to stop after that.
Any ideas on how to continue from here?
