Audi A1 (8X) DPF Sensor replacement - 1.6 tdi 105hp - where is it?
lincoln_dj
Active Member
Lincoln, England.
Got the below VCDS error (bottom of post) relating to the DPF (diesel particulate filter) sensor G505 on a 60 plate Audi A1, 1.6tdi (CAYC) 105hp, so have ordered a replacement sensor.
However I'm struggling to find it! Below shows the ElsaWin workshop manual page, which shows it next to coolant reservoir. Photos below show:
  • Whole engine bay
  • Photo of coolant tank side - no sensor!
  • Back section behind the block (a google suggested this is the sensor, but it looks completely different to both the ElsaWin page and the sensor I ordered using ETKA info.)
  • Right side section, by the air box. only other sensor that seems to have small hoses going to it.
  • Photo of the sensor I ordered.
  • Screenshot of ETKA info.
  • Screenshot of ElsaWin page.
Any tips greatly appreciated! I'm sure i'm missing something completely daft here...
Engine bay
Left side
Back of engine
RHS of engine bay
Sensor
Etka
Elsawin
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KN HW: 03L 906 023 KM
Component: 1,6L R4 CR td H53 9056
Revision: --H53--- Serial number: CVN: F968FA1A
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KN 003010
ROD: EV_ECM16TDI02103L906023KM_003.rod
VCID: 7CFC66FDF79A377397-8028
VINID: 9D196AAAA228A124800C508720FF9D7E4A
2 Faults Found:
7347 - Particulate Filter; Differential Pressure Sensor
P2453 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 17
Mileage: 163457 km
Date: 2023.07.05
Time: 15:37:26
Engine RPM: 1915.75 /min
Normed load value: 32.9 %
Vehicle speed: 53 km/h
Coolant temperature: 71 °C
Intake air temperature: 29 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.682 V
Unlearning counter according OBD: 40
Particle filter: difference pressure-DIP_PF: 0.00 hPa
DPF: offset for differential pressure-DIP_PF_AD[0]: 0.00 hPa
Outside temperature-Ambient temperature: 12.75 °C
Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 0.00 g
Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 0.00 g
Air mass: actual value:: 16.47 g/s
7346 - Particulate Filter; Differential Pressure Sensor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 163455 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: 62 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.988 V
Outside temperature-Ambient temperature: 16.50 °C
Air mass: actual value:: 9.48 g/s
Readiness: 1100 0000
