Hey all,
So I’ve been having a chuffing noise coming from the passenger side of the engine.
Took it to my local engine specialist, they’ve done a job for me before (turbo and injector replacement at £1500) so I know they could be trusted etc. £50 charge for diagnostic, turns out there’s a leak in the exhaust manifold. Also you can feel air/gas if you put your hand next to the exhaust manifold area.
The issue is that they are now looking at getting prices for parts and estimated labour. I’m confused about this as they’ve not opened it up to see exactly what the issue could be.
It could potentially be down to a worn/corroded nut/screw that has come loose or broken. This would be best case scenario.
Also it could be a crack or damage to the exhaust manifold gasket.
Lastly the exhaust manifold would need replacing but this is worst case scenario.
I’m not a mechanic so I may be completely wrong about the above but does anyone think there should be further diagnosis before estimation for repairs are made?
Thank you
