- Joined
- Jun 11, 2016
- Messages
- 175
- Reaction score
- 39
- Points
- 28
Hi all, coming back to these forums as I have recently bought another Audi, I have a 2007 Audi S8, it was imported around a year ago from Japan, car is in excellent condition and has been very well looked after by a Japenese Businessman as the sole owner since new until it was imported.
Aside from an air suspension leak (in the process of receiving parts) the car is perfect, except for this strange electrical issue that appears to be some kind of low-voltage or short.
This issue has been going on for a few months now but has only become more apparent recently, as at first, it only occurred after a 2:30hr drive to Manchester airport, but then didn't occur on the way back, it has happened a handful of times on long drives since then but recently (today) it happened twice on a short 15-20 minute drive, so the issue is getting worse and I need to look into fixing it.
What happens is, out of nowhere, all electronics in the car seem to drop and then immediately come back online, so radio, MMI screen, all dash and lights just died and then instantly recovered. The car throws errors for transmission and brakes but then immediately clears them and the car will continue driving without any warnings or issues at all. However on the way back on this 20-minute journey (may be worth noting I had stopped for around an hour) the issue happened again, except this time the drop in electrical power was enough the stop the transmission from driving, I had to quickly put the car in neutral and cycle the ignition for the car to continue driving (at around 30-40mph). After doing this the car drove fine. A quick check with a multimeter at home seemed to show the battery and alternator in good health. (12.3v engine off, sits steady at 14.00v idle and 14.20v at 2k RPM)
VCDS Scan:
Any ideas, I'm starting to lose my mind with this and I feel I can no longer trust the car on a long journey!
VCDS Scan:
Code:
Saturday,16,September,2023,17:40:47:49881
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ4E87N026251 License Plate: V10 UWU
Mileage: 98640km-61292mi Repair Order: Electrical Fault 1
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 11 31 13 15 16 17 19 1E 28 34 36
37 38 42 46 47 4F 52 53 55 56 57 61 62 65 6C 72 76
VIN: WAUZZZ4E87N026251 Mileage: 98640km-61292miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels:. 07L-910-552-BSM1.clb
Part No SW: 4E0 910 552 HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0060
Revision: 5AH21--- Serial number: AUX3Z0G6727503
Coding: 01060003190F0260
Shop #: WSC 63314 001 1048576
VCID: 5F9BB094FB31B162561-800A
VINID: 9D196AAAA115207780086085040FEAB896
2 Faults Found:
049717 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98385 km
Time Indication: 0
Date: 2023.09.10
Time: 13:50:04
Freeze Frame:
RPM: 650 /min
Load: 26.3 %
Speed: 2.0 km/h
Temperature: 95.0°C
Temperature: 21.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.081 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 98644 km
Time Indication: 0
Date: 2023.09.15
Time: 03:53:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 69.0°C
Temperature: 50.0°C
Voltage: 11.557 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0020
Revision: --H01--- Serial number: 0110368
Coding: 0000001
Shop #: WSC 02313 758 00200
VCID: 2411FF7892D7D2BA4B3-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H49 0500
Coding: 0001927
Shop #: WSC 02313 000 00000
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 C
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G6727503
Coding: 0413184
Shop #: WSC 02311 785 00200
VCID: 58E99B889E1F465A17B-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: None
Part No SW: 4E0 910 769 N HW: 4E0 035 729 A
Component: Interfacebox H43 1480
Revision: 00000000 Serial number: 347FQ077516035
Coding: 0000108
Shop #: WSC 11274 001 1048576
VCID: 372B38343341A922FE1-8062
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000041979
Subsystem 3 - Serial number: 0103.07.070000000100010079ÿ
Subsystem 4 - Serial number: 010079ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000128413
Coding: 0123601
VCID: 1C61C798AAA7EA7AF33-8048
2 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 98616 km
Time Indication: 0
Date: 2023.09.15
Time: 01:12:44
Freeze Frame:
Voltage: 13.20 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 98325 km
Time Indication: 0
Date: 2023.09.10
Time: 10:47:30
Freeze Frame:
Voltage: 11.70 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133001
VCID: 36353530344B502AE57-8062
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: None
Part No SW: 4E0 910 121 HW: 4E0 035 121
Component: MD-Changer H42 0070
Revision: 00000001 Serial number: KE1059V7500190
Shop #: WSC 00000 000 00000
VCID: 57EB98B4930149221E1-8002
Address 11: Engine II Labels:. 07L-910-552-BSM2.clb
Revision: 5AH11--- Serial number: AUX3Z0G6727503
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 98385 km
Time Indication: 0
Date: 2023.09.10
Time: 13:50:04
Freeze Frame:
RPM: 653 /min
Load: 25.5 %
Speed: 2.0 km/h
Temperature: 95.0°C
Temperature: 21.0°C
Voltage: 13.208 V
Address 13: Auto Dist. Reg Labels: 4E0-910-561.clb
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041148
VCID: 2517E27C99ED2BB25CD-8070
4 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 4
Reset counter: 229
Mileage: 98408 km
Time Indication: 0
Date: 2023.09.10
Time: 04:37:00
Freeze Frame:
Temperature: 32.0°C
Voltage: 13.70 V
Bin. Bits: 00100000
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 229
Mileage: 98408 km
Time Indication: 0
Date: 2023.09.10
Time: 04:37:00
Freeze Frame:
Temperature: 32.0°C
Voltage: 11.65 V
Bin. Bits: 00100000
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 221
Mileage: 98384 km
Time Indication: 0
Date: 2023.09.10
Time: 13:50:00
Freeze Frame:
Temperature: 35.0°C
Voltage: 8.58 V
Bin. Bits: 00100000
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 229
Time Indication: 0
Freeze Frame:
Temperature: 27.0°C
Voltage: 12.42 V
Bin. Bits: 11100000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G0FS5D
Coding: 0430707
VCID: 270BE874E3E139A26E1-8072
Subsystem 1 - Serial number: 63328RB402B9EE23X
Subsystem 2 - Serial number: 63428RB402B9F085T
Subsystem 3 - Serial number: 63528RB402B9EFE24
Subsystem 4 - Serial number: 63628RB402B9F0DB%
Subsystem 5 - Serial number: 63729RB402915BC5S
Subsystem 6 - Serial number: 63829RB402915BF1S
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90025071860086
Coding: 0112151
VCID: 2615E570E4EB20AA557-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 N HW: 4E0 920 931 N
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G6001400
Coding: 0048913
Shop #: WSC 33268 002 1048576
VCID: 2E051D50CC1B68EAAD7-807A
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4E0 907 468 G
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0100J077138055
Coding: F5F5DFFF71260E
VCID: 6C81D7583A87DAFAC33-8038
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 4
Reset counter: 206
Mileage: 97773 km
Time Indication: 0
Date: 2023.08.22
Time: 10:12:38
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 B HW: 4E0 035 110
Component: MP3-Changer H46 0350
Revision: 00046004 Serial number: AUZ5ZBG2030766
VCID: 176BD8B453818922DE1-8042
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000057436
Coding: 0000000
VCID: 619FB66CCD458792605-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
Shop #: WSC 56676 001 1048576
VCID: 2C011758FA071AFA833-8078
3 Faults Found:
01583 - Leak in System Detected
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 18
Reset counter: 229
Mileage: 98332 km
Time Indication: 0
Date: 2023.09.10
Time: 12:08:26
01400 - Suspension Level Control
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 224
Mileage: 98325 km
Time Indication: 0
Date: 2023.09.10
Time: 11:58:03
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 229
Mileage: 98336 km
Time Indication: 0
Date: 2023.09.10
Time: 12:17:18
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063338
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 K HW: 4E0 919 887 B
Component: MNS JP H04 0590
Revision: 0000005S Serial number: AUZBZ7G0105064
Subsystem 1 - Part No: 4E1 910 336
Component: Interface Handy H08 0050
1 Fault Found:
02288 - Control Module for Chip Card Reader (J676)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 43
Mileage: 94503 km
Time Indication: 0
Date: 2023.05.06
Time: 15:28:58
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000718400012
Coding: 0036006
Shop #: WSC 64595 001 1048576
VCID: 1D67CA9CB1BDE37204D-8048
3 Faults Found:
00211 - Control Circuit for Rear Illumination Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 190
Mileage: 98640 km
Time Indication: 0
Date: 2022.09.15
Time: 00:18:00
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 221
Mileage: 98340 km
Time Indication: 0
Date: 2022.09.10
Time: 13:04:00
00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 229
Mileage: 98640 km
Time Indication: 0
Date: 2022.09.15
Time: 00:29:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032750
Shop #: WSC 02313 785 00200
VCID: 2019F36886CFCE9A2FB-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040707310094
Coding: 0004840
VCID: 2A0D1140F0F304CA71F-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
2 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 190
Mileage: 90046 km
Time Indication: 0
Date: 2022.01.15
Time: 10:30:14
Freeze Frame:
Fault Priority: 3
Reset counter: 190
Mileage: 90046 km
Time Indication: 0
Date: 2022.01.15
Time: 10:30:14
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 B HW: 4E0 035 466
Component: BO_D3 H06 0180
Revision: 20S00002 Serial number: 01903070008472
Coding: 0000017
Subsystem 1 - Part No: 4L0 910 465 A
Component: BO_D3_SLAVE H41 0780
Subsystem 2 - Serial number: 01304120020030
Subsystem 3 - Serial number: 0213.04.120000000100010030ÿ
Subsystem 4 - Serial number: 010030ÿ
3 Faults Found:
03016 - Motor for Front Right Treble Speaker (V345)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 85
Reset counter: 190
Mileage: 98325 km
Time Indication: 0
Date: 2023.09.10
Time: 10:51:18
Freeze Frame:
Voltage: 12.00 V
Temperature: 29.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 34.0°C
03017 - Motor for Left Front Treble Speaker (V344)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 85
Reset counter: 190
Mileage: 98325 km
Time Indication: 0
Date: 2023.09.10
Time: 10:51:18
Freeze Frame:
Voltage: 12.00 V
Temperature: 29.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 34.0°C
03000 - Amplifier for Digital Sound Package (R184)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 83
Reset counter: 190
Mileage: 98325 km
Time Indication: 0
Date: 2023.09.10
Time: 11:55:56
Freeze Frame:
Voltage: 11.70 V
Temperature: 26.0°C
Bin. Bits: 00000100
Voltage: 11.50 V
Temperature: 27.0°C
Bin. Bits: 00000010
Bin. Bits: 00000000
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000008261
Coding: 0010101
VCID: 1E65CD90BCBBF86A1D7-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032750
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000733
Shop #: WSC 09308 002 1048576
5 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 229
Time Indication: 0
Freeze Frame:
Voltage: 11.90 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 229
Time Indication: 0
Freeze Frame:
Voltage: 11.90 V
Count: 41
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 189
Mileage: 98616 km
Time Indication: 0
Date: 2023.09.15
Time: 01:12:15
Freeze Frame:
Voltage: 9.52 V
Count: 61
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 226
Mileage: 98536 km
Time Indication: 0
Date: 2023.09.12
Time: 16:38:06
Freeze Frame:
Voltage: 13.35 V
Count: 236
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 229
Time Indication: 0
Freeze Frame:
Voltage: 11.90 V
Count: 246
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 290FEE4CF5F50FD2785-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 N HW: 4E0 035 541 R
Component: TUNER Japan H42 0180
Revision: 00000000 Serial number: 325GN077535052
Coding: 0000003
VCID: 2B031444FF091DC28A9-807E
3 Faults Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 226
Mileage: 97209 km
Time Indication: 0
Date: 2023.08.13
Time: 09:44:27
00447 - Function Limitation due to Over-Voltage
Freeze Frame:
Fault Priority: 7
Reset counter: 226
Mileage: 0 km
Time Indication: 0
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 43
Reset counter: 190
Mileage: 91968 km
Time Indication: 0
Date: 2023.03.10
Time: 13:25:35
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 F HW: 4E0 919 146 C
Component: TV analog TUNER H15 0290
Revision: 00000076 Serial number: 00000000015579
Coding: 0000016
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010459
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 341126Q0W1
Coding: 344530393135313035412056413033343131323651305731
Shop #: WSC 65372 001 1048576
5 Faults Found:
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 98386 km
Time Indication: 0
Date: 2023.09.10
Time: 00:02:55
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 98386 km
Time Indication: 0
Date: 2023.09.10
Time: 00:09:52
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 98386 km
Time Indication: 0
Date: 2023.09.10
Time: 00:10:03
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 98386 km
Time Indication: 0
Date: 2023.09.10
Time: 00:10:13
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 98386 km
Time Indication: 0
Date: 2023.09.10
Time: 00:10:23
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032750
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000600058977
Coding: 0222428
Shop #: WSC 11918 001 1048576
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J77109R
Coding: 1121402
VCID: 5CE18798EA27AA7A333-8008
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730720812861
Coding: 0221008
VCID: 2313FC6497D9D582329-8076
End----(Elapsed Time: 02:39, VBatt start/end: 11.5V/11.6V. VIgn 11.6V)-----
