Axle stands
ch1z64
C'mon you's bhoy's in Green
Kilwinning Ayrshire
Needing some help lads , where do u normally put ur Axle stands on the front off ur car as i want to be able to work on my brakes , not sure if they should be placed on the Jacking points . Any help appreciated TA
I've never used axle stands Chic just trolley jacks and 'homemade-wood and rubber' pads under the 'jacking points' like so:
P1000844x P1000890x Jamie 3P1020058MA29968900 0078​
Note, the 'wood and rubber pad' replecates the OEM jack fitting as supplied with the car. I do exactly the same with our TT and SQ5 just a different pad design.
PS: I no longer use Red-Stuff brake pads, only Ferodo Eco-Friction
Hope this helps
I was taught never to work on a vehicle supported just by a hydraulic Jack.
Reactions: andykn and 45bvtc
And you are 100% correct, Steve - I've no excuse... But at 78-years of age it's way to late for me to change or even want to, sorry :whip:
Reactions: Steve D
No problem putting them on the jacking points but won’t the Jack already be there? I normally find somewhere solid such as the chassis rail or the front suspension crossmember.
I put them on the seals as per the arrows then I put the jack also on the seal or cross member, wishbone as a safety precaution incase a stand fails.
Had thirty-plus Audi 8P RS3's (2010/11/12 early RS3 days) through my garage sorting 'low-speed-brake-squeal-issues' and NOT once did ANYONE complain of my 'trolley-jack' support-issues whilst resolving (AUDI couldn't/wouldn't/had ZERO idea - did not even understand the issue: DO they NOW!) their own low-speed-brake-squeal issues: ALL 100% sorted I may add! :thumbs up:
I made sure EVERYONE wore a HARD HAT and SAFETY BOOTS, obviously :thumbs up:
Reactions: NHN
I just like to make sure things have an added level of safety for me & their car, it's not worth my risk for anything to fail.
Reactions: HM3P
I DO SO AGREE!
If you do not know what you are doing, or even question it, then DON'T! Just DON'T!
PERIOD!
I still have the tools and facilities, but not the youth, so will still hand over to others....
I like to think I know what I'm doing, but any tool can break, can't afford a broken back or car on the floor, although I do occasionally just use my trolley, if it's a quickie lol.
  • Love
Reactions: 45bvtc and HM3P
The EASY and BEST and SAFEST answer is to take your 'whatever' to your 'dealer!'
But if the OMG I can't afford that, as we've 5-holidays booked, then whatever!
So funny!
Me/us, did our own LOTUS/TVR?Marcos/AUDI maintenance from late 60's! Could never afford 'others' to do it for us!
Still do 'our' own AUDI (TT/RS3/SQ5) maintenance at 78-years plus
Get over it!
Still using OUR Faithfull trolley jacks, safety boots, hard hats, face masks, etc!
Reactions: NHN
Yeah the old man was old school, used to spend hours fine tuning engines, none of the faff these days, but as with everything, things evolve, not necessarily positively lol.
Reactions: 45bvtc
I sooooo do AGREE! If you NEED to 'BLOCK' it then 'BLOCK' but hey, be SAFE!
If you DO NOT know what you are doing, or question what you are doing, the just 'DON'T!!!
ME? You'll need to excuse me, I don't care anymore!
My 'only' reason to live/help others//care how others 'jack-up' thier car died 96-weeks and 4-days back....
Make sure you wear a hard hat and safety boots.... :friends:
ME? You'll need to excuse me, I don't care anymore! My 'only' reason to live/care died 96-weeks and 4-days back....
Uh mate, you ok, what happened.
  • Sad
Reactions: 45bvtc
No words, Neil, thank you: I'll PM later...
Sometimes I just get frustrated with the pedantics of it all when the answers are oh so simple.
Reactions: NHN
No worries mate feel free.
Reactions: 45bvtc
What is causing that low speed brake squeal? My S3 has started doing this and its becoming quite annoying. Like literally when creeping on traffic light its squealing like a pig.
Typically lack of a suitable anti-squeal shim on the back-plate/non-friction side of the pad. High-frequency vibration between back-plate and pisons = brake squeal.
Mintex have a low-cost self-adhesive anti-squeal shim and for sure, in my experience, it solved the 8P RS3 issue.
See: "Finally the brake fix is out' on the 8P RS3 forum, Feb 22 2013, and you'll find chapter and verse. Any issues PM me.
Reactions: theViTALiTY
Sorry to thread hijack but would the solution apply to A3 8P models? Mine does it.
Think I found it, had to use google rather than forum search:
I looked for jack stand rubber pads but read that they can be dangerous if they slide off the stand so I used some cloth to avoid damaging the chassis
Reactions: 45bvtc
Cause and resolution is the same Andy, however depending on the pad manufacturer, improvement can be achieved using Mintex Ceratec anti-squeal lubricant - but NOT on the friction surface, obviously.
https://www.diycarserviceparts.co.u...ke-disc-caliper-grease-tube-75ml-pad-goo.html​
Reactions: andykn
