Hi all,
The issue started with an intermittent very slightly jumpy gear change into third (in comfort too) and very rarely 5th
that issue remains, however in all the odd gears(3, 5, 7) when ur accelerating 40-50% or more and the turbos nearly at full boost or at full, the revs start to fluctuate without any real power delivery, one time the revs even flew all the way to 5/6k rpm under hard acceleration with again practically no power behind it. Is this the clutch pack going causing it to slip? Or could it be the clutch position sensor in the mechatronics? Heard it might also be the hydraulic seal on the clutch, but honestly don’t know much about autos.
The other issue is that the car isn’t picking up any fault codes, so the diagnosis I took it for was pointless. Also it isn’t counting any clutch slips. I’ve thought it could be a boost leak but would be happening in even gears as well I would’ve thought.
Any help is greatly appreciated
