intermitant car not cranking
drunknspikes3
Member
had my car off the road for a 1.5 year due to finances covid and all that crap got the car moted and taxed and i just need it to work and now it randomly doesnt crank new battery installed new starter motor and still does the not cranking randomly (cannot trust it to use ) so scanned the car for errors and it can back with all this i know there is a eps fault due to the battery being off and i dont have the original head unit so not so not worried about those errors what would the no cranking be related too thanx in advance
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 42 44 46 52 55 56 76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH15--- Serial number: AUX7Z0F9FNI0ML
Coding: 01030003180F0160
Shop #: WSC 107523 636 00337
VCID: 377A955B46804B35B2-8062
2 Faults Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
000010 - Camshaft Positioner (Bank 1 Intake)
P000A - 008 - Slow Response - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 147860 km
Time Indication: 0
Date: 2022.06.22
Time: 04:07:55
Freeze Frame:
RPM: 1208 /min
Load: 33.3 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 6.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.605 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
Shop #: WSC 06314 000 00000
VCID: 72EC644F6D62EE1D45-8026
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
Component: KlimavollautomatH19 0360
Revision: 041362 Serial number: 8P0820043AD
VCID: 6ED4703F795ACAFDA1-803A
4 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 129
Mileage: 147860 km
Time Indication: 0
Date: 2022.01.20
Time: 06:29:52
Freeze Frame:
Voltage: 7.40 V
01274 - Air Flow Flap Positioning Motor (V71)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 21
Reset counter: 129
Mileage: 147652 km
Time Indication: 0
Date: 2021.09.28
Time: 01:47:59
Freeze Frame:
Voltage: 14.40 V
Temperature: 17.5°C
(no units): 33.0
(no units): 46.0
Temperature: 14.0°C
00716 - Air recirculation Flap Positioning Motor (V113)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 129
Mileage: 147860 km
Time Indication: 0
Date: 2022.06.19
Time: 00:06:00
Freeze Frame:
Voltage: 14.40 V
Temperature: 8.0°C
(no units): 201.0
(no units): 47.0
Temperature: 8.0°C
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.26
Time: 02:01:49
Freeze Frame:
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006287207
Coding: F58E5F07A014100000000000000000000008EE175A0500
Shop #: WSC 06314 000 08192
VCID: 4088FE87134E0C8D03-8014
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H12 3720
Revision: 91H12372 Serial number: 0037W0G0GYJ+
Coding: 0071612
VCID: 479AE59B36603BB5C2-8012
Subsystem 1 - Serial number: 63328RB401B73D30G
Subsystem 2 - Serial number: 63428RB401B7738FV
Subsystem 3 - Serial number: 63528RB401B73D04J
Subsystem 4 - Serial number: 63628RB401B7612DM
Subsystem 5 - Serial number: 63729RB401B7EED44
Subsystem 6 - Serial number: 63829RB401B7EE6F9
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418EFB83184405850C-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 J HW: 8P0 920 981 J
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2249F004000150
Coding: 0037418
Shop #: WSC 00011 888 96745
VCID: 3F8AFD7B6EB073757A-806A
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 J HW: 1K0 907 951
Component: J533__Gateway H12 0160
Revision: H12 Serial number: 3200106A06820B
Coding: FD0F07C807000101
VCID: 2E54B03FB9DA8AFDE1-807A
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.26
Time: 00:36:48
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.26
Time: 00:36:48
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 F
Component: Haldex 4Motion 0115
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 3068AE47A3EE9C0DF3-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0F9FNI0ML
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000632
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 234 3305
Revision: 00H22000
Shop #: WSC 00388 210 99160
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.26
Time: 00:36:43
Freeze Frame:
Battery Volts: 12.3 V
DD
Temperature: 26.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 C
Component: KSG H04 0050
Coding: 198000186D288505489AC63300
VCID: 3C708A777FA6686D5F-8068
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000632
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000020
VCID: 295E43238034EDC534-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH03 0020
Address 56: Radio
Cannot be reached
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 00067824830628
Coding: 0000113
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005037530
Coding: 0011422
Shop #: WSC 00847 210 91083
VCID: 3B72896B7AA86F5556-806E
2 Faults Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 146542 km
Time Indication: 0
Date: 2020.10.23
Time: 16:18:34
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.26
Time: 00:36:43
End-------------------------(Elapsed Time: 01:56)--------------------------
Saturday,24,June,2023,14:22:29:52687
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 (x64)
Data version: 20220830 DS341.0
www.Ross-Tech.com
08-Auto HVAC -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
2 Faults Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 147860 km
Time Indication: 0
Date: 2022.06.22
Time: 04:07:55
Freeze Frame:
RPM: 1208 /min
Load: 33.3 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 6.0°C
Voltage: 14.605 V
Revision: 00H13001
Coding: 0021128
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
Coding: 0071612
Coding: 0004042
1 Fault Found:
01304 - Radio
Coding: 0037418
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.27
Time: 00:09:26
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.27
Time: 00:09:26
Address 22: AWD Labels: None
VCID: 55A63FD3BCCC992540-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Cannot be reached
Coding: 0000632
Revision: 00H22000
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.27
Time: 00:09:21
Freeze Frame:
Battery Volts: 14.1 V
DU
Temperature: 27.0°C
Count: 2
Count: 0
SteerAng n.Init
1 Fault Found:
000 - -
Coding: 0000632
Coding: 0000020
Address 56: Radio
Cannot be reached
Coding: 0000113
Coding: 0011422
2 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Mileage: 146542 km
Time Indication: 0
Date: 2020.10.23
Time: 16:18:34
01304 - Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 94
Mileage: 147902 km
Time Indication: 0
Date: 2022.08.27
Time: 00:09:21
End-------------------------(Elapsed Time: 02:57)--------------------------
OK all codes now clear changed the ignition switch k15 relay new battery starter motor works cleaned all the earth cable point I can see still no cranking and no error codes on the vcds any ideas what to try now to get me car to crank?
Found this going to fuse box in the engine bay car isn't cranking so hopefully this is what's stopping it the wire was rubbed on the battery tray no idea what the wires for
Screenshot 20230709 185642 comandroidgallery3d
Reactions: ahtcap
So the car has started every time since the wire was redone had to cut a bit of the battery tray away..
.. bad bad bad design flaw by audi just need to permanently connect it and tape it all up again sooo if anyone has any random non start or electrical problems start at the fuse box wiring behind the battery Check for chaffing of the wires
IMG 20230711 183641
