Headlights upgrade question
mrvinhojr7
Herceg Novi
Hi folks, I have question if anyone can tell mr by any chance how hard it is and is it even possible to put newer headlights from redesign model of A3 from 2008+ to my 2006 model , as well is it possible to do the same thing with stop lights and on top of that same question is for bumpers from redesign model????
Yes of course you can but it will require a full front end facelift including front panel, wings, bonnet, bumper, headlights, bcm, wiring etc.
Plenty of conversion guides online, have fun with your research.
Reactions: NHN
Hugh, do you think is it worth doing it?
Yeah, the headlights on the facelift models (2008.5+) are different shape and so is the front bumper, grille and the hood. So in my opinion, not worth it.
The tail lights, however, are the same. I have replaced my original tail lights with the LED style lights.
This is what I had to do for my North American 2006 A3 model:
- replace both outside (corners) and inside (mounted in the hatch)
- get a conversion harness (Kufatec is what I got)
- supply +12V to the inner lights (for the LED ring)
- possibly make slight changes in coding so the correct lights come on for brakes, signals, tail lights
I got the Euro style tail lights, using amber bulbs for turn signals.
Cheers,
IMG 5383
Cheers,
Amazing job man and thank you very much for explanation, it will be helpfull definitely...on top of that I have one more question, is tit possible to fit new cluster from redesign model and how hard is it to get it done?
I am guessing you’re talking about the instrument cluster (dashboard) ??
Here is some info I found on vwvortex forums, not sure if it’s still relevant as the posts are quite old …
