esp+headlight range control faults. Have had a VCDS scan but still unsure.
Jacobwatersx
Cornwall
Been having these 2 faults come up as per my previous post, both come and go at the same time so are definitely linked somehow. had a scan done which I’ll post below. I’m confused as to weather it points towards the instrument cluster being an issue as there’s multiple “Control Module in Instrument Cluster - no signal / communication- intermittent” faults. Or an issue with the abs sensor.
Any help appreciated.
scan:
Friday,09,June,2023,16:36:17:23195
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ8P2BA085808 License Plate: HW60BFF
Mileage: 195280km-121341mi Repair Order: 1
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 61 77
VIN: WAUZZZ8P2BA085808 Mileage: 195280km-121341miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number: AUX7Z0J9FNS08D
Coding: 0143000C18070060
Shop #: WSC 06314 000 00000
VCID: 41DEB3129D8C63B2405-8014
VINID: 9D196AAAA220092440205200209678D5C4
4 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 - - Intermittent
Freeze Frame:
Fault Status: 00101111
Fault Priority: 0
Fault Frequency: 25
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 28.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 12.192 V
U1017 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 195281 km
Time Indication: 0
Date: 2023.06.09
Time: 14:52:21
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.954 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 48.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.192 V
U1017 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 195272 km
Time Indication: 0
Date: 2023.06.08
Time: 19:42:16
Freeze Frame:
RPM: 1727 /min
Load: 10.2 %
Speed: 14.0 km/h
Temperature: 98.0°C
Temperature: 42.0°C
Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13424012492A00FFC81302E492210081380800
Shop #: WSC 19482 000 1048576
VCID: 75B617C295C49F122CD-8020
7 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
Freeze Frame:
Count: 0
Count: 0
Count: 12800
Count: 8208
Count: 41984
Count: 8192
Count: 0
Count: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 13:12:09
Freeze Frame:
Count: 3
Count: 2
Count: 28928
Count: 8193
Count: 44032
Count: 0
Count: 1792
Count: 0
03841 - RPM Sensor Rear Left: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 60
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:39:19
Freeze Frame:
Count: 0
Count: 6
Count: 12288
Count: 71
Count: 44288
Count: 0
Count: 63488
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 63
Mileage: 195239 km
Time Indication: 0
Date: 2023.06.07
Time: 18:40:51
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 65
Count: 51201
Count: 255
Count: 0
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 4
Reset counter: 69
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:51:35
Freeze Frame:
Count: 3
Count: 2
Count: 12288
Count: 128
Count: 44288
Count: 0
Count: 63488
Count: 0
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 3
Reset counter: 69
Mileage: 195265 km
Time Indication: 0
Date: 2023.06.08
Time: 19:20:47
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 67
Count: 50432
Count: 2830
Count: 1024
Count: 0
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 20
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:39:49
Freeze Frame:
Count: 16391
Count: 2
Count: 12288
Count: 64
Count: 46336
Count: 0
Count: 63744
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000762 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78A81EF68ED6E27A37B-802C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 4E000A2FA005F000207041E00000094C421E25AA304DD928E4000E840041
VCID: 3828DEF6C256227AF7B-806C
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:00:35
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
ON
01504 - Bulb for License-Plate Light (X)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 59
Mileage: 194833 km
Time Indication: 0
Date: 2023.05.29
Time: 22:00:44
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36831031500256
Coding: 000003
VCID: 48C8AE36B2B652FA87B-801C
No fault code found.
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB009HA6S Dataset Number: 8P0909602M 0004
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 4FFA852A575885C2C61-801A
Crash sensor for side airbag: driver side:
Serial number: 34928RB400005E2E97A0
Front Passenger's Side Airbag Crash Sensor:
Serial number: 35028RB400005E260056
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005E2E904N
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400005E2FA1CZ
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005EB5083Q
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005EB5185U
1 Fault Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 49
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
VCID: 46D4A00EB4A2448A757-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 Q HW: 8P0 920 982 Q
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2249J004004962
Coding: 0260428
Shop #: WSC 12345 067 57207
VCID: 47CAAD0AB3A85D828E1-8012
4 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 49
Time Indication: 0
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:00:59
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 111694 km
Time Indication: 0
Date: 2015.01.26
Time: 11:20:38
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:49:24
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 250511F1001628
Coding: 350101
Shop #: WSC 19489 000 1048576
VCID: 372ADDCACF482D02FE1-8062
5 Faults Found:
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 13:12:09
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 49
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:04
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 44
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:04
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0J9FNS08D
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74B02AC69EBE861A1B3-8020
2 Faults Found:
02619 - Communications Wire Adapter Set
Freeze Frame:
Fault Status: 00111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 194698 km
Time Indication: 0
Date: 2023.05.27
Time: 00:07:53
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:47:46
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H05 0220
Revision: 0000011S Serial number: AUZBZ7KD207534
Coding: 0209725
Shop #: WSC 00294 210 104145
VCID: 3430EAC6D23EC61ADB3-8060
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 69
Mileage: 170504 km
Time Indication: 0
Date: 2021.04.03
Time: 00:01:22
Freeze Frame:
Voltage: 12.10 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:30
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:50
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:51
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195270 km
Count: 806
Clock: 20:21
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000564
VCID: 49CEAB32A5BCABF2985-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313EE3D22D2CF332B05-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
Freeze Frame:
Voltage: 11.88 V
DD
Temperature: 8.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 69
Mileage: 195283 km
Time Indication: 0
Date: 2023.06.09
Time: 16:16:16
Freeze Frame:
Voltage: 14.25 V
DU
Temperature: 35.0°C
RPM: 1766 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0000564
VCID: 4ACC943EA0BAA0EA91F-801E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 3C20C2E6FA6E0E5A133-8068
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Mileage: 8 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Reset counter: 69
Mileage: 194792 km
Time Indication: 0
Date: 2023.05.28
Time: 09:51:52
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209725
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 69
Mileage: 170504 km
Time Indication: 0
Date: 2021.04.03
Time: 00:01:22
Freeze Frame:
Voltage: 12.10 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:30
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:50
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:51
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195270 km
Count: 806
Clock: 20:21
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 0322085A
VCID: 71BE23D2E1ACB332F05-8024
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650242601
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005250484
Coding: 0011422
VCID: 74B02AC692BE861A1B3-8020
2 Faults Found:
02503 - Output Wire to Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:09
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:47:46
End----------(Elapsed Time: 01:32, VBatt start
