- Joined
- Oct 27, 2006
- Messages
- 2,851
- Reaction score
- 110
- Points
- 63
Hi. Again thanks for taking the time to reply in person. Social media is a double edge sword for sure.That would be methank you for the kind words. I am new to YouTube, learning a lot along the way. Production quality improves with each video so please, bear with me! Trying to impart some of the things I've learned to you all.
Fun fact, we have over 500 cars globally running rolling launch control on the factory ECU, we have never lost an engine to rolling launch control other than one that was already running 700hp on the stock engine. Please have a little bit more of an understanding of what you are referencing exactly as you are bashing my product, there are different strategies that can be implemented to use rolling launch. Spark cut and fuel cut, also do a little bit of research into the nmax function. This way you will be a lot more prepared when going onto bash any companies RAL implementation.
Was not expecting this video to blow up as much as it did but I think some need to do a little bit of more real world research. I deal with a very high number of DAZA and DNWA engine failures on a monthly basis. Read the comments on that video, join the American RS3 groups on Facebook, there is a failure every single day no matter who the tuner is. Fact! We built 36 engines last year alone. Zero were tuned by us, we have not had a failure since we introduced engine safety algorithms 3 years ago. There are 30+ engine blocks with holes in them at my shop, countless crank, anyone is welcome to visit at any time.
The fact of the matter is that the stock knock control system on this engine is simply not enough to save the engine when things go wrong on tuned cars, the stock knock control system is designed for stock boost levels and stock ignition. It would be nice if this engine had ion sensing capabilities within the coil packs for added protections.
Ontop of that we find it to be common practice for tuners to be numbing down the knock sensors to make power. For example I commonly see 18 even 19 degrees of ignition at the top end with the waste gate pinned and cars running on 99 octane fuel (stage 2) with NO timing corrections. On the stock knock control sensitivity, it is not possible to run more than approx 15/16 degrees of ignition on 99 octane fuel. If you are running 18/19, your knock sensitivity has been dulled.
Please please do your research, another one worth looking into is the boost profile on the RS3 8Y vs RS3 8V. Boost comes in slower on the 8Y which again proves audi know about these engines shooting rods from heavy amounts of boost at low rpms, yet we have tuners making 2bar at 2500rpm. Just because the turbo can do it, does not mean it is safe for the engine. This is another reason why the stock turbocharger will kill more engines than any hybrid turbo ever will. The stock turbo is capable of creating an insane amount of boost at extremely low rpms. 2bar of boost at 2500rpm is very different to 2bar of boost at 7000rpm. Practical example, think about the strain on your knees on a bike going up a big hill in a high gear and low speed vs high speed.
It is commonly mentioned 'limit the torque to stop the rods from exiting on the engine' This is extremely vague and means absolutley nothing. Again as above, 700nm at 2500rpm vs 700nm at 7000rpm are very different things. Another issue is, all tunes making over 700nm on the stock turbocharger as over 700nm can only be made between approx 2500rpm and 3500rpm which is a danger zone, engine has little momentum. The stock turbo is not capable of making that kind of torque past 4k rpm, which is why it is normal to see the waste gate pinned past this point to try and create as much boost as possible.
If knock sensitivities were left alone, boost came in at 3300-3500 as per 8Y boost profile funnily enough, ignition was capped at 15.75 we would not see half as many failures as we do.
I advise everyone to log their cars. My understanding of this engine, what it can take and what it cannot take is a result of personally stripping over 75 engines over the last 5 years, analysing the software and identifying the root cause of failure on each car. I know why these engines fail.
Another one that gets me.. Rod bearing failure isolated to a single rod which we see a lot of. Always gets blamed on the oil pump by experts/professionals in this industry. WRONG. Rod bearings get chewed up from running too much ignition at higher rpms, out of all of the engines rebuilt by us we have only replaced oil pumps when a rod has gone through it. All of our engines go out the door with 3 year 40k mile warranties so go figure! We have never seen an oil pump fail on this engine to date. If it was oil pump failure we would see evidence of it across the engine, not just on one cylinder.
This reminds me of a time back in 2015, on another popular uk based RS3 forum, I purchased a pre facelift RS3 and posted about how catastrophically bad the braking system was on it. I got a lot of hate from all of the forum members and other owners of the car. I am starting to feel this is natural defence mechanism for most. Can people not handle uncomfortable truths about this car? I got banned from that forum. Fast forward to 2017 and it was widely known and accepted on how bad the braking system is on that car, hell, Audi even changed the design of the brakes completely on that exact same model of car, got rid of the wavey discs completely.
Don't even get me started about the transfer box which is a sealed for life unit on the 8V but a service every 20k unit on the RSQ3 and 8Y RS3. It is the exact same box on the 8Y and RSQ3. Audi make mistakes all the time!
Please, if anyone has any questions fire away. I'd love to answer them all for you.
However... My 2018 rs3 DAZA is currently stock. Serviced as it should be and about 46k on now. I would like to maybe go stage 1 but nothing more. Maybe with the elbow and larger intake pipe? Your video doesn't make it clear if STOCK cars are likely to fail ? STAGE 1 cars to fail ? Is it at stage 2 or above the limits are pushed too hard by tuners? also... Which tuners? name and shame the ones that you have proof of dulling down of safety features? I have decided in my ownership an oil change by me every 6 months as well as the garage service plan can only help? is this correct?
I await your reply.
Thanks in advance for clearing up these questions for me/ us
