ESP/ABS + auto levelling headlight faults , help!
Jacobwatersx
Cornwall
I’ve been getting these ESP/ABS + headlight levelling faults randomly on my 2010 a3 with HIDs, sometimes it’ll only stay on for a few seconds then go.
But both faults come on and go away at exactly the same time
what could be causing both of them to go at once? And help really appreciated !
Bad ground, battery aged, fuse point coming loose, fuse on way out, need to scan to know mate.
I was getting all sorts of errors until I replaced my old and tired battery, once it was replaced they all disappeared
I’m getting the exact same on my 2011 s3 mate. Also sometimes the car has a weak start up.. always starts but sometimes struggles more than other times. Let me know if you find out the problem
Probably the original battery
Did you get yours scanned yet or no? Will update once I have
Hi mate have had a scan down, will paste it below. There’s a load on there as I don’t think any of its been cleared recently. Any idea? It’s only the abs and headlight range control I’m getting faults for, everything else seems fine. Thanks!
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 55 56 61 77
VIN: WAUZZZ8P2BA085808 Mileage: 195280km-121341miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
2E-Media Player 3 -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 1010
61-Battery Regul. -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0030
Revision: AAH18--- Serial number: AUX7Z0J9FNS08D
Coding: 0143000C18070060
Shop #: WSC 06314 000 00000
VCID: 41DEB3129D8C63B2405-8014
VINID: 9D196AAAA220092440205200209678D5C4
4 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 - - Intermittent
Freeze Frame:
Fault Status: 00101111
Fault Priority: 0
Fault Frequency: 25
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 30.0°C
Temperature: 28.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 12.192 V
U1017 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 8
Reset counter: 255
Mileage: 195281 km
Time Indication: 0
Date: 2023.06.09
Time: 14:52:21
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.954 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 48.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.192 V
U1017 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 195272 km
Time Indication: 0
Date: 2023.06.08
Time: 19:42:16
Freeze Frame:
RPM: 1727 /min
Load: 10.2 %
Speed: 14.0 km/h
Temperature: 98.0°C
Temperature: 42.0°C
Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13424012492A00FFC81302E492210081380800
Shop #: WSC 19482 000 1048576
VCID: 75B617C295C49F122CD-8020
7 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
Freeze Frame:
Count: 0
Count: 0
Count: 12800
Count: 8208
Count: 41984
Count: 8192
Count: 0
Count: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 13:12:09
Freeze Frame:
Count: 3
Count: 2
Count: 28928
Count: 8193
Count: 44032
Count: 0
Count: 1792
Count: 0
03841 - RPM Sensor Rear Left: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 60
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:39:19
Freeze Frame:
Count: 0
Count: 6
Count: 12288
Count: 71
Count: 44288
Count: 0
Count: 63488
Count: 0
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 63
Mileage: 195239 km
Time Indication: 0
Date: 2023.06.07
Time: 18:40:51
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 65
Count: 51201
Count: 255
Count: 0
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 4
Reset counter: 69
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:51:35
Freeze Frame:
Count: 3
Count: 2
Count: 12288
Count: 128
Count: 44288
Count: 0
Count: 63488
Count: 0
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 3
Reset counter: 69
Mileage: 195265 km
Time Indication: 0
Date: 2023.06.08
Time: 19:20:47
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 67
Count: 50432
Count: 2830
Count: 1024
Count: 0
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 20
Mileage: 194791 km
Time Indication: 0
Date: 2023.05.28
Time: 09:39:49
Freeze Frame:
Count: 16391
Count: 2
Count: 12288
Count: 64
Count: 46336
Count: 0
Count: 63744
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0170
Revision: 000762 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78A81EF68ED6E27A37B-802C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Mileage: 0 km
Time Indication: 0
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 G HW: 8P0 907 063 G
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 4E000A2FA005F000207041E00000094C421E25AA304DD928E4000E840041
VCID: 3828DEF6C256227AF7B-806C
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:00:35
Freeze Frame:
Term 15 On
Voltage: 11.90 V
ON
ON
Term 50 Off
OFF
ON
01504 - Bulb for License-Plate Light (X)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 59
Mileage: 194833 km
Time Indication: 0
Date: 2023.05.29
Time: 22:00:44
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36831031500256
Coding: 000003
VCID: 48C8AE36B2B652FA87B-801C
No fault code found.
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB009HA6S Dataset Number: 8P0909602M 0004
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 4FFA852A575885C2C61-801A
Crash sensor for side airbag: driver side:
Serial number: 34928RB400005E2E97A0
Front Passenger's Side Airbag Crash Sensor:
Serial number: 35028RB400005E260056
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400005E2E904N
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400005E2FA1CZ
Crash sensor for front airbag: driver side:
Serial number: 35547RB400005EB5083Q
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400005EB5185U
1 Fault Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 49
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004012
VCID: 46D4A00EB4A2448A757-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 Q HW: 8P0 920 982 Q
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 2249J004004962
Coding: 0260428
Shop #: WSC 12345 067 57207
VCID: 47CAAD0AB3A85D828E1-8012
4 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 3
Reset counter: 49
Time Indication: 0
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:00:59
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 111694 km
Time Indication: 0
Date: 2015.01.26
Time: 11:20:38
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 49
Mileage: 194600 km
Time Indication: 0
Date: 2023.04.03
Time: 00:49:24
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 250511F1001628
Coding: 350101
Shop #: WSC 19489 000 1048576
VCID: 372ADDCACF482D02FE1-8062
5 Faults Found:
01771 - Control Module for Headlight Range (J431)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 13:12:09
00381 - Databus Instrument Cluster
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 49
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:04
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 44
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:04
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01004 Serial number: AUX7Z0J9FNS08D
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8P0 035 785 HW: 8P0 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 74B02AC69EBE861A1B3-8020
2 Faults Found:
02619 - Communications Wire Adapter Set
Freeze Frame:
Fault Status: 00111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 56
Mileage: 194698 km
Time Indication: 0
Date: 2023.05.27
Time: 00:07:53
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:47:46
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H05 0220
Revision: 0000011S Serial number: AUZBZ7KD207534
Coding: 0209725
Shop #: WSC 00294 210 104145
VCID: 3430EAC6D23EC61ADB3-8060
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 69
Mileage: 170504 km
Time Indication: 0
Date: 2021.04.03
Time: 00:01:22
Freeze Frame:
Voltage: 12.10 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:30
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:50
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:51
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195270 km
Count: 806
Clock: 20:21
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000564
VCID: 49CEAB32A5BCABF2985-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 232 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313EE3D22D2CF332B05-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Time Indication: 0
Freeze Frame:
Voltage: 11.88 V
DD
Temperature: 8.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 69
Mileage: 195283 km
Time Indication: 0
Date: 2023.06.09
Time: 16:16:16
Freeze Frame:
Voltage: 14.25 V
DU
Temperature: 35.0°C
RPM: 1766 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0000564
VCID: 4ACC943EA0BAA0EA91F-801E
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 3C20C2E6FA6E0E5A133-8068
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 49
Mileage: 8 km
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 36
Reset counter: 69
Mileage: 194792 km
Time Indication: 0
Date: 2023.05.28
Time: 09:51:52
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0209725
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 69
Mileage: 170504 km
Time Indication: 0
Date: 2021.04.03
Time: 00:01:22
Freeze Frame:
Voltage: 12.10 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:30
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:50
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195230 km
Count: 706
Clock: 15:51
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:50:40
Freeze Frame:
Mileage: 195270 km
Count: 806
Clock: 20:21
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 0322085A
VCID: 71BE23D2E1ACB332F05-8024
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650242601
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005250484
Coding: 0011422
VCID: 74B02AC692BE861A1B3-8020
2 Faults Found:
02503 - Output Wire to Radio
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 61
Mileage: 194796 km
Time Indication: 0
Date: 2023.05.28
Time: 10:50:09
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 61
Mileage: 195237 km
Time Indication: 0
Date: 2023.06.07
Time: 15:47:46
