Hi all, I finally installed the 4pot Macan/Brembo calipers and 345 VBT discs on my A3 2.0.
I know it's an overkill, but I was sick of warping the oem discs and opted for better brakes.
Anyways, I got the calipers, pads, brake lines & discs installed, changed the brake fluid with the ATE type 200 dot4, got the system bleeded twice and still there's a very little change in the way the car stops. Brake pedal is imo even softer than before and it does not "nail" you when pressed.
Yes, the car stops, but after a continuous pressing of the brake pedal, and sometimes I have to lift my foot off a bit and press again to get it to a complete stop.
I tried with "pumping" the pedal - sometimes this makes the brakes work more aggressively, sometimes it does not.
Before retrofitting, I've read dozens of threads, and I was assured by the ppl I got the kit from that no brake pump/cylinder shall be exchanged.
I seem to not get what the issue is then? I was told that the A3 and S3 brake pumps/cylinders are not different.
I would very much appreciate if you guys give an advice what should I check further or install / code, etc!
P.S. - I haven't changed the rears, still running on the 210 discs at the back.
This is how the kit looks, pads were not installed, we were just checking whether the oem wheel would fit without spacers.
