Coolant leak
Deadlysub
Merseyside
I’ve had my 2016 252 TFSI B9 saloon for three years and it’s been completely trouble free in that time but it went in for a service a couple of weeks ago, oil change, new spark plugs and S tropic oil change. They found a coolant leak and quoted a £1,000 to fix (it was a main dealer)
I’ve checked today and there is definitely a leak and want to take it to a specialist rather than a main dealer.
Does anyone know a decent specialist on the Wirral, I’ve done a google and Unit 20 seems to get good reviews.
Can’t help you regards Indy, but this is a useful link regards possible coolant leak on 2.0TFSI. Dave Sterl is Very knowledgeable so may give you a pointer.
What coolant is used in Audi 2.0l engines is it G12 ? I wouldn't mind getting a top up bottle
Thanks for posting that link, I have spoken to Unit 20 and they have suggested the same.
The car is now booked in
Not a surprise that it is likely to be the thermostatic valve housing. Had mine replaced a couple of years ago but fortunately the cost was covered by Audi. Also had a leak from the A/C condenser repaired at the same time and now have oil leaking from the gearbox sump. 1 leak could be considered unlucky but 3...
I had mine done under extended warranty which I paid less than £500. Not many people like dealer warranty but in this days Audi warranty is the best out there for peace of mind.
Coolant leaks might not seem like a big deal, but it could create a hazardous situation for your car’s engine. Without the proper amount of antifreeze, your engine could overheat (or freeze in winter months). Because it plays such a critical role in how well your engine runs, coolant should be checked regularly. That’s especially true for older cars, which may not operate as efficiently as newer models. Drift Boss
Hi i got told the same thing on my recent service , just checked my coolant and it has dropped slightly.
I‘ll be booking mine in at an independent garage , I believe the part is made by INA so will source one from Autodoc .
Hope you got it sorted.
Just an update on this, I took the car to Unit 20 today and they replaced the thermostat, bell housing and water pump. Total cost £771.
Reactions: rasA4
