Racingline Adjustable Front Drop links Used for approx 10,000 miles.
Condition as photos.
£120
Sold car so selling parts.
Our Adjustable Drop Links are an essential upgrade to any lowered or performance car. If you’ve lowered your car, our Adjustable Drop Links are an essential upgrade to zero the pre-load on your anti-roll bar geometry, plus add stiffness and precision by replacing the stock rubber joints with ball joints. The drop link attaches the front anti roll bar ends to the front damper. The OEM links were made the length they are for a reason – to compliment the standard ride height. But when you lower ride height, the car will now be pulling your anti roll bar ends up, pushing it out of its operating window, and forcing the link to sit at a sharper angle. Solid, motorsport-spec ball joint ends mean much more direct response when turning in to corners. These links were developed for our race cars to allow the anti roll bar to work the way it should. Adjusting the height of droplinks to the equivalent of the lowering amount is a must. 250mm for cars running standard ride height or with lowering springs.
VWR420000 – 250mm length OEM & Sport Springs
£120
