VCDS Scan with Electric Damper fault ,Adaptive head light Warning
Darren McDonnell
Wirral
Hi I have been getting an Adaptive headlight warning on the dash for a week or so. Its not on every drive but does show up most of the time.
I have now done a scan and it is showing the below, There seems to be a lot a reference to the Electronic dampers.
Would this all be connected and where would I need to look for the adaptive headlight fault?
I have attached the scan, Thanks guys
Sunday,22,January,2023,16:04:55:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
www.Ross-Tech.com
VIN: WAUZZZ8K3FA032593 License Plate: BF64YVK
Mileage: 207640km-129021mi Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 22 30 42 44 46 47 52 53
56 5C 5F 62 72 A9
VIN: WAUZZZ8K3FA032593 Mileage: 207640km-129021miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
30-Special Function II -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
5C-Lane Maintain. -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CREC) Labels: None
Part No SW: 8K2 907 551 A HW: 4H2 907 551 A
Component: 3.0l V6 TFSI H10 0006
Revision: --H10---
Coding: 0A2500340547010B2800
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TFS0218K2907551A 003002
ROD: EV_ECM30TFS0218K2907551_003.rod
VCID: 3169A0C36029530EB4-8064
1 Fault Found:
24194 - PCV Valve Malfunction
P052E 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 207297 km
Date: 2023.01.06
Time: 16:57:57
Engine speed: 700.50 /min
Normed load value: 14.1 %
Vehicle speed: 0 km/h
Coolant temperature: 89 °C
Intake air temperature: 28 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 14.531 V
Unlearning counter according OBD: 30
Air mass: actual value (mg/stroke): 163.45 mg/stroke
Throttle valve angle: 3.239 °
Oxygen ctrl factor with precontrol correction: 0.01 %
Oxygen control factor with precontrol correction: bank 2: 0.32 %
Engine status: Idling
Charge air pressure: actual value: 0.471 bar
Ambient air pressure: 1.008 bar
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K0 927 166 HW: 0B5 927 156 K
Component: 0B5 30TFSIRdW H02 0004
Revision: --H02---
Coding: 000001
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 72EB6FCFA5AF28160D-8026
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V2.clb
Part No SW: 8K0 907 379 CP HW: 8K0 907 379 CP
Component: ESP8 quattro H09 0020
Revision: -------- Serial number: --------------
Coding: 295DCE01
VCID: 09192823A0394BCE5C-805C
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 JE HW: 8K0 907 064 JE
Component: BCM2 2.0 H14 0650
Revision: 00002001
Coding: 01B14040000000000000
Shop #: WSC 06325 000 00000
VCID: 7CF741F7FFEB6E6657-8028
Subsystem 1 - Part No SW: 8K0 959 754 BH HW: 8K0 959 754 BH
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0514000093476003
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Serial number: 0214000132480016
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8K2 820 043 AP HW: 8K2 820 043 AP
Component: KLIMA 3 ZONEN H04 0122
Revision: D0000000 Serial number: 01160720140354
Coding: 6624028080
VCID: 77FD5EDBC6CD4D3E3A-8022
1 Fault Found:
01230 - Left Footwell Vent Temperature Sensor (G261)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 37
Reset counter: 163
Mileage: 206476 km
Time Indication: 0
Date: 2022.12.10
Time: 12:53:16
Freeze Frame:
Temperature: 2.0°C
Speed: 18.0 km/h
Voltage: 13.90 V
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000858586702
Coding: 260000118234AFE22F8140C000001D0D4F9DC30A27090201000008004400070200020024000000
Shop #: WSC 06335 123 12345
VCID: 7AFB47EFF5DF505645-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110714 H06 0080
Serial number: SWF14077115700
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 22911833
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001607140798
Subsystem 4 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: B1880C37000000000001
1 Fault Found:
00471 - Control Module for Elect. Regulated Dampers (J250)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 7
Reset counter: 167
Mileage: 207493 km
Time Indication: 0
Date: 2023.01.08
Time: 16:28:06
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 B HW: 8K0 907 561 B
Component: ACC3 H11 0100
Serial number: 00000000000000
Coding: 003352
VCID: 3169A0C36829530EB4-8064
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 C HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0054
Revision: 00000000 Serial number: 26061400750001
Coding: 030181
VCID: 3A7B87EFB55F905605-806E
2 Faults Found:
00776 - Level Control System Sensor; Left Front (G78)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 7
Reset counter: 167
Mileage: 207493 km
Time Indication: 0
Date: 2023.01.08
Time: 16:28:06
Freeze Frame:
Bin. Bits: 00000010 00000000
Bin. Bits: 00000000 00000000
03262 - Comfort Restriction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 7
Reset counter: 167
Mileage: 207493 km
Time Indication: 0
Date: 2023.01.08
Time: 16:28:06
Freeze Frame:
Error Code: 2
Bin. Bits: 00000000
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 N HW: 8K0 959 655 N
Component: AirbagVW-AU10 H48 0610
Serial number: 003KFDC2V44I
Coding: 30544435363030303030554A3052384B3053
Shop #: WSC 57849 001 1048576
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
VCID: 489FED27F3B3F2C683-801C
Crash sensor for side airbag: driver side:
Serial number: 6334MSME465E2A4CU
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME465E011EJ
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME4F434840J
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME17442D44H
Crash sensor for front airbag: driver side:
Serial number: 63732SME6C4556442
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME59434C600
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 M HW: 8K0 953 568 M
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372NGP000G1
Coding: 0000FE
VCID: 4487F917C79BD6A66F-8010
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 B HW: 8K0 920 983 B
Component: KOMBIINSTR. H35 0564
Revision: 00200000 Serial number: ZCK57EX5F
Coding: 33EF0900DF012600010400
Shop #: WSC 06325 123 12345
VCID: 3467A9D7973B6626DF-8060
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z147110F51
Coding: 80CF07FF00
VCID: 4C97D137EFCB1EE6A7-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 7343774003
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 14199000853021200410
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 B HW: 8K0 907 163 A
Component: 4 Wheel Drive H15 0100
Serial number: 001007140001003
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 2F6DA6BB761D45FEA2-807A
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000106801
Coding: 01010101000000000001000102
VCID: 2D51BCB3741137EE90-8078
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8T0 959 793 P HW: 8T0 959 793 G
Component: TSG FA H09 0305
Coding: 011C02204021410001
VCID: 56A3335F2107543601-8002
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8K0 909 144 J HW: 8K0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0010757997
Coding: 100001010001
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 387F9DE783538246F3-806C
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0341897905
Coding: 011F062280B908808330013680000047
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813032603605
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8T0 959 792 P HW: 8T0 959 792 G
Component: TSG BF H09 0305
Coding: 011C02204C21410001
VCID: 55A134533C015F2E08-8000
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 97
Mileage: 205200 km
Time Indication: 0
Date: 2022.10.08
Time: 12:45:24
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000406768
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B87EFBD5F905605-806E
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109G00E7951329
Coding: 010103010000000001
1 Fault Found:
02984 - Connection between Impedance Converter 2 and Window Antenna
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 162
Reset counter: 166
Mileage: 204880 km
Time Indication: 0
Date: 2022.10.06
Time: 19:22:38
Freeze Frame:
Voltage: 11.80 V
Address 5C: Lane Maintain. Labels: None
Part No SW: 8T0 907 217 A HW: 4E0 907 217 C
Component: J759 HC 0040
Revision: 00H08006 Serial number: 60021470900100
Coding: 0023201
VCID: 377D9EDB464D8D3EFA-8062
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 167
Mileage: 207493 km
Time Indication: 0
Date: 2023.01.08
Time: 16:28:06
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 8R2 035 670 M HW: 8R2 035 670 E
Component: H-BNT-EU H48 1036
Revision: -------- Serial number: 208GZ0EB000980
Coding: 110101000206F9FD6F80CF5E00000403040000000100000000
VCID: 3E738BFFA977BC7639-806A
Subsystem 1 - Part No: 8R0 060 884 FC
Component: EUR 2018 2601
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130GX0E3091676
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000001933446
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
5 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 204880 km
Time Indication: 0
Date: 2022.10.06
Time: 19:22:33
Freeze Frame:
Text: DUA130,Front,M,0,0,6
02244 - Button in Control Head is Stuck
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 6
Reset counter: 163
Mileage: 207517 km
Time Indication: 0
Date: 2023.01.08
Time: 16:44:58
Freeze Frame:
Voltage: 14.50 V
Hex Value: 0x0002
not available
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 156
Mileage: 207297 km
Time Indication: 0
Date: 2023.01.06
Time: 17:26:04
Freeze Frame:
Bin. Bits: 00000000 00000001
00862 - Antenna for GPS Navigation (R50/R52)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 184
Reset counter: 166
Mileage: 205918 km
Time Indication: 0
Date: 2022.11.20
Time: 12:59:25
Freeze Frame:
Voltage: 12.40 V
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 24
Mileage: 204880 km
Time Indication: 0
Date: 2022.10.06
Time: 19:22:31
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H
Component: TSG HL H07 0305
Coding: 010C02204021210001
VCID: 59B9386350197B4E2C-800C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H07 0305
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8K0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0006
Serial number: 140623200260
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
End-------------------------(Elapsed Time: 04:25)--------------------------
Update. Done a clear 2nd scan and a short drive. I got the same adaptive warning so done a fresh scan and I get the below.
Would the level sensor affect the other faults or I'm I looking at the wrong part?
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 168
Mileage: 207642 km
Time Indication: 0
Date: 2023.01.23
Time: 10:18:25
Coding: 030181
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 207642 km
Time Indication: 0
Date: 2023.01.23
Time: 10:18:23
Freeze Frame:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 168
Mileage: 207642 km
Time Indication: 0
Date: 2023.01.23
Time: 10:18:23
Freeze Frame:
Error Code: 2
Bin. Bits: 00000000
Coding: 0023201
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 168
Mileage: 207642 km
Time Indication: 0
Date: 2023.01.23
Time: 10:18:24
Update on the Update
I have managed to get to the car and remove the wheel to find that the arm on the level sensor was snapped at the plastic ball joint.
Audi wanted £172 for a new one but I have taken a punt at a replacement for £50
I'll get it fitted and see what happened and if the codes stay clear.
If anyone has any advice on the suspension faults I'm still happy to hear them
So update. The parts arrived and I have just used the tie rod off the cheap copy and refitted the Audi original.
done a short drive and the codes seem to have stayed off so hopefully all sorted.
Also fitted a replacement temp sensor for the AC and did the service.
Only just seen this I’d have said you’d found your problem as the common link between the headlights and the dampers from your log would have been the level sensor.
