Notification of oil change and service Virtual Cockpit
Poland
Hello, I have problem. For some time, after deleting the service, a message appears that an oil service is required in 15,000 km. The message appears after the ignition and after turning off the car. It is very tiring. Could anyone tell me where to look for a solution?
Wysłane z mojego SM-G988B przy użyciu Tapatalka
What procedure did you follow for for the SRI reset? The behavior from the cluster is surely very annoying. If using VCDS, i've included a link below. i have a 2017 with VC and having used VCDS, i haven't had any issues.
https://www.ross-tech.com/vag-com/cars/audi_sri.html
Situation above seems one of the adaptation channels maybe inadvertently modified. You may want to try the Ross_tech technical forums maybe.
