Hi. i recently purchased a 2017 s3 sportback. After a couple of days it became apparent that the interior heating isnt working correctly. My previous s3 would have relentless hot air after about 3 minutes but this one not so much..
Heres my issue:
This one seems to take a good 8 minutes to get even a little bit of heat.
The main problem is the drivers side is only luke warm (through dash vent, window & footwell) even when the engine is up to temperature. Im pretty sure the passenger side is not as hot as it should be however it is certainly warmer than the drivers side.
Something to note, the previous owner said that the water pump was done just before i bought it. Could there be an airlock in the coolant system?
Bar an airlock i guess im looking at flaps or heater matrix right? I have VCDS, is there anything i can check with it?
any advice welcome.
Heres my issue:
any advice welcome.
