The Highest Arts: Audi RS 3 performance edition
A225585 medium
Limited edition of 300 units with exclusive features
The RS 3 performance edition3, the sportiest compact model from Audi Sport, is fast and a true street artist. Developed for maximum performance, the special edition boasts 299 kW (407 PS) of power and a top speed of 300 km/h (186 mph). In addition to well-known top technologies like the RS torque splitter and ceramic brakes, it has RS bucket seats for optimized lateral support and a whole host of exclusive design elements.
Top chassis technologies in series production​
Negative wheel camber, stiffer wishbone, RS-specific tube stabilizer with a higher spring rate – all these measures already ensure high driving dynamics and stability in the standard RS 3. The RS 3 performance edition3 features RS sports suspension with adaptive damper control as standard equipment. It continuously and individually adjusts each shock absorber to the road conditions, the driving situation, and the mode selected in Audi drive select. Pressure and rebound damping have been increased in comparison with the previous generation RS 3, meaning that the shock absorber takes up more of the force that is passed from the chassis. The result is tighter handling. Electromagnetically actuated valves, which regulate the flow of the hydraulic fluid, provide the necessary amount damping power within ten milliseconds of the precise moment the driving situation requires. To do this, sensors measure the vertical acceleration of the body and the movement of the individual wheels relative to it. This information is processed simultaneously in the damper control unit and the modular vehicle dynamics controller, which means that each individual wheel optimally takes the car’s performance to the road. This includes supporting the body during fast cornering as well as braking and acceleration, for example with launch control.
With the RS Torque Splitter, the RS 3 performance edition3 uses technology that, on the one hand, increases stability – for example in wet conditions – and, on the other hand, increases agility and reduces understeer during dynamic driving. This is achieved through two electronically controlled multi-plate clutches that actively distribute the drive torque with full variability between the rear wheels. A maximum of 50% of the driving power is directed to the rear axle; in RS Torque Rear mode all of the rearward drive torque is intermittently transmitted to the wheel on the outside of the curve. This enables drifts on closed-off routes. In combination with RS Performance Mode, the torque splitter distributes torque between the rear wheels in such a way that almost neutral handling is achieved with little understeering and oversteering, ensuring optimum performance on the racetrack. This allows you to accelerate earlier at the end of the curve for faster lap times.
The RS 3 performance edition3 runs on semi-slick Pirelli P Zero “Trofeo R” tires as standard equipment – 265/35 on the front axle, 245/35 on the rear. Due to their specific rubber compound and asymmetrical tread, these performance tires offer particularly high grip in dry conditions, thus increasing stability and lateral grip. In keeping with their characteristics, the semi-slicks are mounted on cast aluminum wheels in motorsport design. The 19 inch rims in dark gray matte, exclusively available on the special model, have a striking design with ten cross‑spokes and display the RS branding. Behind it, the standard six-piston ceramic brake takes a firm grip. Their discs on the front axle measure 380 x 38 mm (15 x 1.5 in.). The high-performance brake system, with a specially adapted pedal curve on the brake booster, is ten kilograms (22 lbs) lighter and more heat-resistant than the steel brakes. The reduction in unsprung masses brings advantages in highly dynamic applications. The rear axle has a floating caliper with 310 x 22 mm (12.2 x 0.9 in.) single-piece steel discs. The brake calipers are painted blue to match the specific interior.
Exclusivity and dynamism made visible​
The special model shows its leading position in the RS 3 portfolio with a wide range of new design‑elements and equipment: in addition to the motorsport-design wheels and the RS‑sports exhaust system with black tailpipe trims, the Audi rings and the RS 3 badge on the front and rear are also black. This is in perfect harmony with the particular finishes on the RS 3 performance edition3: these include the pearl-effect colors Nogaro Blue, Arrow Gray and Daytona Gray as well as Sebring Black Crystal Effect and Glacier White Metallic.
A225640 small
Perfection down to the smallest detail is also visible in the light. The standard Matrix LED headlights with darkened bezels and the LED taillights feature a dynamic flashing light and RS‑specific staging when unlocking and locking. When the RS 3 performance edition3 is opened, the digital daytime running light, consisting of 15 LED segments, displays the “checkered flag” on the passenger side and the “3‑0-0” on the driver side – based on the limited number of units and a top speed of 300 km/h (186 mph). Upon closing, “R-S-3” lettering appears in the pixel field below the main headlight instead of the “3-0-0.” While driving, the checkered flag lights up on both sides as a daytime running light. Another distinguishing feature is an entrance LED in the front doors: it projects “#RS performance” onto the ground next to the car.
The special model also shows its exclusivity in the interior. For the first time in the RS 3*, bucket seats are available as standard equipment, ensuring outstanding lateral support during dynamic cornering. Like the outer rear seats, the seat center panel also has contrasting blue honeycomb stitching. The material used for this is Dinamica microfiber fabric, which is combined with pearl Nappa leather on the side bolsters. Below the headrest, the black funnel aperture incorporates large RS lettering and, like the Carbon matte back of the seat back, emphasizes the sporty character of the special model. In addition to the full-surface blue belt straps, the contrast stitching on the center armrest, the door armrests, and the steering wheel are also in blue. The same applies to the floor mats and the trunk mat in black Velour, which also features RS lettering. For better orientation during sporty driving, the Alcantara steering wheel, which is flattened at the bottom, features a 12 o’clock marking – also in blue.
A225618 medium
Specifically in the special model, the background image on the 10.1 inch touch display has a carbon look and shows the characteristic 2.5 TFSI 1-2-4-5-3 firing sequence. The RS monitor also integrates displays of coolant temperature, engine and transmission oil, g-forces, and tire pressures. At the same time, the Audi virtual cockpit plus provides information on performance-related data, such as lap times, g-forces, and acceleration in seconds from 0‑100 km/h (62 mph), 0‑200 km/h (124 mph), quarter mile, and eighth mile.
The RS 3 performance edition3 is limited to 300 units – as illustrated by the carbon decorative inlay on the passenger side with the badge “1 of 300.” The model can be ordered at prices starting at € 75,000 as a Sportback and € 77,000 as a Sedan. The edition will be delivered from early 2023.
A225733 small
Reactions: B7/RS4
A New Chapter in Emotional Design, Performance, and Comfort: The Audi e-tron GT quattro
  • 259
Audi continues to expand its electric vehicle lineup with the introduction of a new entry-level model in the e-tron GT family. Priced from £88,555 (OTR), the new Audi e-tron GT quattro is...
Nine generations of success: the new Audi A6 meets its elders
  • 365
Audi has built almost ten million C-series vehicles. The ninth generation is now on sale in Europe – the A6 Avant. A great opportunity for a family photo with Audi employees presenting their C...
Intermittent Fasting for Athletes: Does It Help or Hurt Performance? What Coaches Can Learn
  • 300
https://ru.freepik.com/free-photo/h...larm-clock-plate-blue-background_29320055.htm
Intermittent fasting (IF) is an eating pattern that alternates between fasting...
Why Audi’s Partnership with Sauber Could Shake Up F1 Starting in 2026
  • 539
F1 Racing
The 2026 Formula 1 season is set to introduce significant changes, including the expansion of the grid to 11 teams, marking the first time since 2016 that the...
Redefining the business saloon. Audi Expands A6 Lineup.
  • 1,088
Audi is adding a refined new model to its A6 series: a classic business sedan that sets new benchmarks in design, aerodynamics, and comfort within the premium full-size category. With a drag...
