Rs38v123
Scotland
The two error codes are appearing on scan.
P0016 - Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A.
P0420 - Catalyst System Efficiency Below Threshold Bank 1
The noticeable issue I’m having with the car is the I get the following error code Max Engine Speed: 4000 rpm matched with an EPC light. As well an Engine Management Light.
I’ve had the car checked by a reputable Audi specialist, they advised that timing figures are all in line and eliminated the need for chain replacement. They said the cam solenoid valves need replacing and that should sort the issues. I have since changed both the valves and now the error has gone from intermittent to permanent even after clearing the codes it’ll come straight back on.
Does this sound like I’ve done something wrong or has anyone got any experience as to why this 4000 rpm restriction would be on the dash.
2015 PFL RS3.
Anyone got any insight?
AFAIK those are simple OBDII codes from a code reader, you need to get VCDS or a dealer ODIS on it first, start looking at live readings of what those things are doing.
I don't know for sure but the wiring for those 2 things could be in the same location, if someone has been messing with the car in the past, wiring damage is not unheard of.
