Aux Coding RNS-E
D.rc
United Kingdom
Hi i have added an AUX adapter to the back of my RNS-E and now i need it coded.
Can i code it myself using OBDELEVEN ? / What vcds cable does the b7 need?
Can someone on here code it for me?
What version does my RNS-E have to be to code aux in as I'm unsure.
Thanks for any help
Thanks for any help
Where are you located? You could try the vcds map.
Reactions: D.rc
Need to code it in 37.
Once coded you need to reset the unit for it to show up.
Mk1 RNS 192 with firmware 0650 or above is needed or any MK2 193 unit
Reactions: D.rc
You can code it with OBD11 the same as using VCDS.
Do buy that rubbish cable you posted.
I coded an RNSE yesterday for a guy who fitted an adapter in the Aux port, but his software in RNSE was to low for the port to show up,
So I told him to buy an update disk.
