PDC retrofit fuse
Fraysa
AUDI
Hi,
I’m in the process of retrofitting rear PDC to my 2011 A3 sport back. Since there isn’t much information online, I wanted to ask which fuse am I supposed to use for the PDC.
I’m using a Kufatec harness which has two CAN wires, and one wire with a pin that looks to be like a fuse pin.
Some threads here say to use fuses 14 & 18 - why two? But reading online fuse box diagrams say that fuse 4 is in charge of PDC (among other things).
Any one knows the OEM route?
This post has a dropbox link with my pictures from when we did front and back PDC and PLA.
Hi,
thanks for the info! We only got to complete the installation today. since fuses 5 & 6 were already used by the car (Bi-Xenon headlights leveling modules) we had to settle for another free fuse (number 11 if I’m not mistaken which is for high beam assist).
tapping into the CAN lo/hi wires was a PAIN. I had to get under the steering wheel with my body upside down to do it, and it took a good hour to carefully splice the wires.
The good news is that the module finally responded through VCDS so I assume the connections are OK. Unfortunately , I was unable to code it. An error about an unlicensed interface kept popping up, even though I have a genuine HEX V2 and I coded other modules with it.
I’ll have to check this matter with RossTech, however I am using a module from Lamborghini Aventador (8P0-919-475N). I’m not sure if the module is the issue but I’ll check with Ross tech.
can you post the coding you used? You didn’t mention it in the PowerPoint.
On this post we can find the screenshots I took while coding. I hope they help. Remember mine also has front and back sensors, and PLA.
The gateway cables were a pain yeah!!!!
